Updated d1.2 skyNETU.sys for SS2-USB?Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Hi peeps, Wonder if any of you have any knowledge of the SS2-USB version. Have just switched from the PCI version, only to find that when applying the diseqc 1.2 plugin, that there is no skyNET.sys file in windows\system32\drivers! Instead there is skyNETU.sys, but this is not the same, at 479KB as opposed to the 429KB of the original skyNET.sys and diseqc-updated skyNET.sys files. Please help me out before I have a major toy-throwing tantrum. Too late, there goes teddy.... | ||
| Member Join Date: 13-08-2004
Hi, Sorry , I have no answer for you. I would like also invest 2x money to USB compared to PCI version of SkyStar2. But, I can not find any info about diferences between them. I want to be sure that USB version is compatible with SW (AltDVB) and HW used with PCI version. Including decoding capabilities and interfaces ...(Phoenix/Smartmouse... - card readers...) I would appreciate if you can confirm that. | ||
My System: Dreambox 7000, Skystar2 | Thanks, I already have my answer. There is no option to address the diseqc motor from the SSUSB. The only way I came up with was to use one of those mickey mouse inline diseqc gadgets to drive the motor to one of four fixed sat locations. Didn't fancy losing half my signal in the process though. Since then I've come up with a far better way of driving my dish over an HTTP link... Had to buy a Dreambox to do it though... I cannot guarantee that the SSUSB is compatible with anything, but I have had it working with MyTheatre V2.76, and ProgDVB V.latest. S*ftcams work, and I can decrypt everything that I could on my PCI version. As it does not drive my motor directly, it has been consigned to the growing pile of junk in the corner of Command-Central. The only advantages I can see over the PCI version are that the heat generated goes straight to the upper atmosphere without toasting my graphics card, and of course, you can use it with a laptop... I assume that your card programmers are for use with something else, as they are of no use with the SSUSB? I don't use AltDVB. Stick. | ||
| Thanks a lot for useful info. Great idea to navigate motor though html link and DreamBox. Fortunately, I have bought dm7000 month ago I am pleased to see ss2usb works correctly when compared to PCI version. My question about alt-dvb was only because I noticed that alt-dvb is probably most popular dvb-viewer. About card-readers... PCI version can access thorugh serial port so-called Phoenix interface -> enables access Crypt*works original smartcards. Maybe ss2usb can do the same ? | ||
| | #5 | |||
The drivers are virtually identical, about 80 bytes are different if I remember correctly from my comparison. | |||
| d12, skynetusys, ss2usb, updated |
Similar Threads | ||||
| New soft ware for Infinity usb Programmer. | rabbi | Cards & Programmers General | 1 | 07-09-2004 01:05 AM |
| Updated cam using laptop but... | benny | Matrix Reloaded, Revolutions and CAS interface | 3 | 25-02-2004 06:12 PM |
| ican someone give me instruction.problem with infinity usb phoenix | fotisbak | Cards & Programmers General | 2 | 17-02-2004 11:43 AM |
| Interactive Millionaire updated | net1 | Daily Satellite and Broadcast industry News | 0 | 26-11-2003 06:21 PM |
| How to use Infinity USB programmer. | T24 | Tutorials & How To guides | 1 | 10-10-2003 07:51 PM |
