TWO LNB & DISEQC PROBLEM WITH SS2
Old 24-06-2004   #1
Cool TWO LNB & DISEQC PROBLEM WITH SS2
Hey people, I have a problem with diseqc on my Skystar 2 card! Only one lnb is working on Astra 19,2E but the other is on Hotbird 13E and doesn't seems to be alive! Lnb on Hotbird is tested with meter during a setup of a dish and have a signal, but diseqc won't switch on it. I have Technisat 4.2.11 software. Progdvb also doesn't work (4.39.6).
What diseqc is needed for Sky star2, because I heard that some types won't work with it?
Thanks!
Dj Alf & Munja, Serbia
djalf is offline   Reply With Quote
Old 24-06-2004   #2
BGonaSTICK's Avatar
Not sure what your problem is, but for starters, try installing this plugin in your /plugins folder.
http://www.satellites.co.uk/php-bin/...ad.php?t=24370
Old 24-06-2004   #3
Jaffer's Avatar
My System: Samsung A300W with component output Hotbird & Astra2
You have to configure disquc - say lnb position 1 for 13E and position 2 for 19,2E
Every little helps and a little help goes a long way!
Jaffer is offline   Reply With Quote
Old 24-06-2004   #4
Wink Diseq 2.0!!!
Thanks guys, I found what is the problem, I think! My diseqC is 2.0, but SS2 support only 1.0 ver!!! I will replace it and let you know what happened!
Thanks!
Old 24-06-2004   #5
kalamar
Posts: n/a
why didnt you say that you were using a motor in the first post? cause Disky2 needs motor.2lnb need disky1 only,card no do care about disky stuff at all,program is likes disky stuff so set in prog and forget about what card likes.can see ALT-DVB like disky-2 but me no like ALT-DVB so use what youse needs thete so can see tv. MT me is like 1 and ProgDVB 2 ,so youse is choicer understand now old man ?
Old 01-05-2006   #6
My System: AMD64 - 3200+ 2GB DDR 400Mhz SkyStar2
Exclamation 2lnb & ss2 problem
here is another problem with ss2... maybe it's not a problem but i just cant figure it out how to make things work! Using "DVBViewer" (from skystar2 instalation disk) everything works fine... but progdvb doesnt want to switch lnb.s (satelites) as i change the channel!! i've upgraded ss2 drivers to 4.4.0 and still there is the same problem... i have found a way to switch to another lnb by using "TechniSat DVB\Setup4PC" and manually choose transpoder on other satelite... after that progdvb can use only that lnb... inside progdvb i've tried every single posible combination with DiSEqC configuration but nothing...
any idea what i should do??? pleeeaseee
p.s.
progdvb v4.72.4
fixed satelite dish with 2 lnb.s
tino_du is offline   Reply With Quote
diseqc, lnb, problem, ss2
Similar Threads
Diseqc Switch to 2 dishes problem slayter DISH SETUP: Single sat, Multi-Sat & Motorised systems 7 26-08-2005 06:24 PM
SS2 with an external diseqc 1.2 positioner? bobnuts1 Satellite PC Card Receivers & Internet by Satellite 0 02-10-2004 10:23 PM
Antenna Feed switches: 12V & Diseqc jeallen01 DISH SETUP: Single sat, Multi-Sat & Motorised systems 3 16-02-2004 11:56 AM
is this a diseqc problem doggy DISH SETUP: Single sat, Multi-Sat & Motorised systems 14 05-09-2003 02:44 AM
SS2 and DXR2 refinechange Satellite PC Card Receivers & Internet by Satellite 0 23-06-2003 01:43 PM
