yanksee/prog dvd problemDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 09-05-2004 Location: north yorkshire near Middlesbrough
| Hi all I can`t seem to get it working Prog dvb is installed and working and i have managed to find chanells on astra 19e and hotbird. I tried putting yanksee in but dont think it works ? downloaded version "Yankse-1-22.2-TT-W98" and put it in prog dvd folder, deleted xp version(i`m running millenium) but when i go to pluggins in prog dvb there isn`t anything there. where have i gone wrong? what chanells should i now be getting? can i delete the data only (red and green disk icons) without causing problems? I have read the guides but am still strugling any help please scuggy | ||
| Specialist Contributor Join Date: 29-07-2003 Location: Chorley, Lancs
My System: Innovative, Diseqc Motor, 80cm dish | ya dont deserve to get it working if ya using windows ME!!! ;o) have ya got ALL the files for yankse, i beleive its split up into 2 downloads these days. plus ver 1.30 is te lastest i think? | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." |
Yep he's right ya know.. Yankse needs the contents of the Yankse common files folder put into the ProgDvb dir as well as the 1.22 or 1.30 dll file let us know how ya doin with it good luck | ||
| Guest
Posts: n/a
| Yankse is not comissioned for Win ME only 98(2best) and NT5+ unicode. youse is better to use an older version of Yankse until you get it mastered,the new versions do not contain internal MECM data and this must be in external file.You will not have autoroll with it set up the way you have it. Best things happen when Fenrir and nagra directory is in ProgDVB root too.Me do suggest Yankse 1.07.0 to begin out with.So you not go nuts and give up. | ||
| | #5 | ||
| Ive now downloaded the new version 1.3 for win me and put it in the same folder as prog dvd (deleted ver 1.22)along with the yankse common folder it came with. is the folder the same as the root directory or should i be putting it somewhere else.You scowl at me using win me, should i upgrade to xp or not? thanks for the reply Scuggy | ||
| | #7 | ||
| Guest
Posts: n/a
| youse is got that correct Win2000 all the way.scuggy For a newbie yer walkin in deep water,you ought to try what I posted for you,I been doing this stuff since day 1 and I do watch tv everyday all day. new Yankse is buggy ,its well known,old version works fine and I see no difference in new features just more problems with external MECM | ||
| | #9 | ||
| Guest
Posts: n/a
| :BgOnAsTiCk: ------------- Greetings ! what is the oldest version that will do S%CA2 and C7nax ? what im saying is to use a version that dont rely on external MECM data. I use 1.07.0 because it works flawlessly for me now if you are trying to do something that this version wont do then you do need one that will do the job. Just try to find a version with internal MECM BgOnAsTiCk do youse know/suggest something? | ||
| | #10 | ||
| ive actualy got yanksee in prog dvd pluggins now but still dont see any extra chanels. I have`nt got win 2000 so i`m going to try xp instead. Ill keep you posted on how i get on | ||
| | #11 | |||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 |
From memory, 1.3.0.0 was the first to do the latest flavour of S2 (nanos, 9x, Via 2 and MT for 0070 etc.) and does current C*nax nano 63. The latter was first supported in V1.2.2.2. V1.3.0.1 is a bugfix release, and that's what I'm on. I agree that the bigger it gets over time, the more bugs are logically introduced, and the more that are fixed from last time. Point is, you gotta move on at some point, so bite the bullet and do it. P'raps you'll get XP now? | |||
| | #12 | |||
| Guest
Posts: n/a
bigStIcK are you complaining about Win2000 ? XP is Spyware ! I have many copys of XP laying around, Even the "corporate" edition they call the "Devils Own" I just dont like it I want control of my computer not Billie boy. <grin> | |||
| | #13 | ||
My System: Dreambox 7000, Skystar2 | LOL, I have nothing against W2K, it's pretty good, it's just that I will always go with the latest version unless it is too buggy to use, which XP isn't. I know Devilsown very well. To be honest, it's exactly the same as the corporate version of XP, the only difference between all the released PRO versions being the VLK, which tends now to be generated with the Bluelist KG, as the original DO VLK was blacklisted in SP1. XP is not spyware. Turn off all the phone-home shit, and use a good aftermarket firewall. Even WU is safe, though I refuse WRM client updates. We'll see about SP2. Bring on Longhorn! | ||
| | #16 | ||
| Regular Member Join Date: 28-06-2004 Location: Bonn, Ostend
| Have you looked in the Yankse monitor window. It should show if it is doing anything. It needs to be set "Active". or alternatively use this Yankse.ini data to edit yours (when Prog is not running) [yankse] Disabled=0 Log=0 LogECM=0 LogPMT=0 LogFirstECM=0 ReadPMT=1 AutoECM=0 FilterBogusECM=1 FilterUnknownECM=1 AllowAutoPIDS=1 LogBadKeys=0 LogCW=0 CWDelay=750 ShowOSD=1 ForcePMTCA=0 Language=0409-enu [CardServer] server= port=-1 enabled=0 | ||
| dvd, problem, yanksee or prog |
Similar Threads | ||||
| Have a problem MPEG2 DVD conversion | mgharbawy | Computer Discussion | 4 | 21-06-2004 10:02 PM |
| Picture Problem !!! | Malteser | Cams and decoders General | 2 | 29-02-2004 09:00 PM |
| Have a problem with Vision Plus | mgharbawy | Satellite PC Card Receivers & Internet by Satellite | 1 | 15-02-2004 10:47 PM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
| Aston to Diseq poitioner problem | BazelAd | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 4 | 20-08-2003 07:21 PM |
