Problems With MultiDec Booting.Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Guest
Posts: n/a
Problems With MultiDec Booting. After a hard drive crash I can,t get MultiDec to boot any more.I used to use it all the time and found it the best program for logging.I,ve tried Versions 8.1b and 8.2.I have no IRQ conflicts and have read everything I,ve found on the matter for the last 3 weeks.It must be a problem with software or setting up as I can get ProgDVB-WatchTV to work o,k But I want to do some logging and prefer MultiDec over Gizlog or MLog(Which work O,K)as you can see what your logging on screen as your doing it.I downloaded new versions and tried but all I get when booting is SAA7146 No Bytes 3072 suitable DVB Fail Hardware SOMETIMES: DVB-Hardware SAA7146 Bytes 254036 Firmware 0x01670000 No Decoder-Init Fail Suitable DVB FAIL Hardware I,m running 1.3gig with 20gig hard drive and 512meg memory. Running TechnoTrend 210 Software Have tried older drivers also. Rebel. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Hmm, sounds like a tricky one Rebel, can't say that I have any particular experience with Multidec and I would guess from the lack of replies that other members who are using the software have not experienced similar problems. The only thing I would say is that with some DVB software, any existing version of software must be completely removed prior to installation. | ||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | Hi Rebel Obviously there's something different in your PC system which won't allow Multidec to load properly. Perhaps, as Rolf is suggesting, something left over from the crash. Assuming your PC is completely "clean" as it were, you could try the following link if you haven't done so already. http://www.ro.feri.uni-mb.si/cborg/mdpedit.html Ii is in English and there's an email help facility for any bugs. Best of luck anyway. Jimbo | ||
| Guest
Posts: n/a
Thanks guys. Maybe as rolfw said I have conflicts with other versions.As I,ve installed that many different versions on earlier as I had an IRQ conflict.Now maybe I need to completely Wipe it all clean and start over now I have solved the IRQ conflict.I will let you know how I get on. Rebel. | ||
| booting, multidec, problems |
Similar Threads | ||||
| Sky+ recording problems | pjb | Sky+ (Plus) and PVR Systems | 4 | 17-06-2004 11:46 AM |
| Problems with 30W Nagra? | rolfw | Matrix Reloaded, Revolutions and CAS interface | 0 | 29-09-2003 12:01 PM |
| Few people seek help for sex problems | net1 | The Meeting Place | 0 | 22-08-2003 08:11 PM |
| Problems... Help ! | iwearflares | Analogue systems | 2 | 11-08-2003 08:01 AM |
| Multidec 8.2 problems | MansellMindy | Satellite PC Card Receivers & Internet by Satellite | 4 | 13-05-2002 08:47 PM |
