Can anyboby help???
Old 05-07-2004   #1
Lucifer's Avatar
My System: Phoenix Apollo ci converted to OpenBox. Sky_star 2 PCI card. Nokia DBox2c. Sagem Dbox2c. 60cm Channel Master @ 28° ALPS LNB. 60cm Channel Master @ 19° Syntec 2000LNB. Diseq Switch. Panasonic TU-DSB30. Duolabs Dynamite & Cas2+ interface. Matri
Can anyboby help???
Hi all, Can you tell me if I need a plugin for ProgDVB to switch a Global 2 way Diseqc switch or should ProgDVB (4.40) be able to control the switch without extra plugins. I also need to know if my card supports Diseqc, its a technisat SkyStar 2 PCI but I'm not sure of a revision number etc for it i.e. do all past and present SS2 cards support diseqc? In the device list on ProgDVB it only states: Disable power on lnb, Transport stream and 22Khz Control, there is no mention of Diseqc, it lists my device as a SkyStar 2 Version 1.08 and API version 1.23. Hope this is enough info to go on. If I do require a plugin could you point me in the right direction plz? Many thx, Lucifer. I've only had my set up about 1 week and with help from this forum i've got 60cm dish with 2 lnbs, 1 at 19 east and the other at 13 east, ProgDVB up and running with Yaknse plugin and softcam files! Keep it up. thanks,
I need an answer if pos' cos' I'm waiting to buy a Diseqc switch!!!
Lucifer is offline   Reply With Quote
Old 05-07-2004   #2
rolfw's Avatar
Real name: Rolf
The SS2 supports DiseqC 1.10, so should be fine with your switch, don't have ProgDVB installed at the moment, but it should have the appropriate settings in LNB setup.
Rolf
anyboby
