yanksee encrypte 100% ?Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 16-07-2004
| hello, I installed mytheatre and yanksee with my satellite card Hauppauge directed towards hotbird but I cannot see SOME crypted channels like MTV... Can any body help me ? thanx ! | ||
| thank you so much for reply, i had the last version of softcam.key but it doesn't work with some channels ! i can show multivision 1-2-3-4-5-6-7 for exemple but i can't show mtv2pop or mtv hit ... or some others crypted channels, please i have another question, can i use yanksee with prog provided by hauppauge nexus, the last version 2.17 ? waiting for ur replays | ||
| | #4 | |||
| Guest
Posts: n/a
The program provided with thw Hauppauge dont use the MDwrapper so no MDplugins , best is use MyTheatre 2.76 or the latest versions of ProgDVB. | |||
| | #6 | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | I have not been using my SS2 for a while (been playing with the Dreambox), but is this true that even though Sly Kitaly is working on the Dreambox it is not possible to watch it on PC based cards?? | ||
| | #7 | |||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 |
Though this may seem a bummer, fear not as good news is never far behind. Pick up the latest version (V1.0.4.0) of a plugin called S2emu.dll from TCD and other good places. Now don't get me wrong, I'm Vlinders biggest fan, but during my day-long testing of it, it rocks. I've replaced Y* with it for now. The hash and mask tables are hard-coded into the .dll, so you don't need anything other than the .dll and the s*ftcam.key file (which you should put in the root dir, not the MDPlugins dir). Very neat and tidy. Stability is better, channel switching times are faster, and it seems to be getting updated regularly. It also does C*nax, and other stuff.... Here's the readme :- S2emu v1.04 ----------------------- v 1.04 Added Conax. Fixed Nagra autoupdate on Hispasat channels and fixed MECM algo for TvCabo. Autoselecting of ECM pids. Enable/disable of module (Check menu). Auto selecting pid on FullX channels(no need to add ECM pid 03EB). Tested with ALT-DVB, My Theatre and ProgDVB(with SkyStar2 card). v 1.03 Very fast Nagra autoupdate(tested only on Polsat).Keys are saved directly in SoftCam. If it fails to save keys, use Info window and enter key manually in SoftCam. Note: Use complete rescan of chanels, and if some program don't work select ECM Pid manually. Where possible in DVB programms set Packet Size to 184. Put file "SoftCam.key" in root dir of DVB programm. v 1.02 Added Nagra (tested on Polsat). Please report if it works with other providers. No more FreeX, they changed algo. v 1.01 Less freezing on SHL. FreeX works only on Hotbird Transponder:12207,Pol: H, Symbol: 27500. v1.00 Tested in ALT-DVB. Working S*ca,S*ca2,VIACCESS and SHL. For FullX add ECM Pid= 1003(Hex:03EB) and CAID to 0000 or 1FFF. For now hash and mask tables are in .dll. Best regards from Croatia. Many thanks to Italian friends from digitalfreesat !!! Post your comments on "www.dvbs*ft.net". MarS | |||
| | #8 | ||
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Hey BGonaSTICK Now this is what I call a reply! Well done! *Hands over BGonaSTICK the "TG's Plain English / Useful Answer of the Week Award" medal* Cheers, I will try it out tonight! TG | ||
| | #9 | ||
My System: Dreambox 7000, Skystar2 | | ||
| | #10 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Hey you two, get a room. | ||
| | #11 | ||
| Guest
Posts: n/a
| I have tested it with my situation and am sorry to say it dont work for me ![]() However if it will just update the softcam.key file with new keys it may be the answer to the new version of Yankse not doing that. When used by itself,nothing gets decrypted,then I turn on Yankse and all is fine again. I have tried about 5 different softcam.key files and also tried some mods on them and no go fer me. And I have noticed that the external MECM data it seems, is required for Nagra decryption,so it may be a good replacement for Fenrir should the need happen. but its something to play with on rainy days (today!) | ||
| | #12 | ||
| Regular Member Join Date: 03-07-2004 Location: India
| please tell me if I can recieve pay channels without subscribing I have Nextwave dx 600 reciever with available cam such as via, nagra, conax etc. How can I edit my recievers key with remote. PLZ help me | ||
| | #13 | |||
| | #15 | |||
yaks Italia. | |||
| | #16 | ||
| Member Join Date: 14-07-2004
| hey guys, I have a problem with s2emu and MyTheatre 3.19RC1.taht thing doesn´t work.I tested version 1.03 ,1.04 and 1.05 with Mythetre 2.96 ,3.12 and 3.19 and nothing.I´m using a Typhoon DVB-s card ci (Twinhan or VisionPlus),winxp pro,pentium IV 1.5ghz.with Progdvb is everything allright but not with mytheatre.even the name "s2emu" doesn´t appears in plugins menu...please help | ||
| | #17 | ||
My System: Dreambox 7000, Skystar2 | Frankly, those versions of MT are recognised as being unstable at best. IMHO, I would go back to MT V2.76 (the last free version), generally accepted as being the most reliable, and which I personally know to work with this plugin (although not with your card). If you go this route, be really sure to uninstall all other versions, and manually scan for, and delete any components not cleanly uninstalled. Especially files in Windows/system32. Also remove all other plugins with a similar function. STICK | ||
| 100%, encrypte, yanksee |
