My Theatre problemDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 23-05-2004
Hi I've been using MT quite happly for 2 months, but I've had to format the Pcs harddrive, now when I've re-installed MT I'm unable to view encrypted channels. I have Yankse 1-22-2 common files and the yankse 1-22-3-tt and the latest softc*m key from cardmania yet the sod won't decrypt, can anyone give me the correct instructions for where these files are supposed to go cos I must be missing something. sorry for being such a pratt, but it's doing my head in. thanks for any reply | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | My recomendation would be to use the new S2emu.dll V1.04 (in 'MDPlugins') and the latest Mach1 s0ftkey (in MyTeatre root dir) both available on TCD. The only other thing you will need is the MDWrapper.dll (automatically placed in 'Plugins') that comes with MT2.76 if you select it as an install option. Will open S*ca S2 (Sly Italy) and C*nax when we get the new keys (worked with last weeks C*nax keys 'till they changed yesterday). You then won't need Y*nkse. The version you quote is very old now anyhow. | ||
| Hi I've done as u said and everything is in place, no picture! I'm on Thor and nothing is showing, I thought I had the latest softc*m key, got it this morning using the key downloader, has a working one been issued or are we still waiting and could it be the one I've been using is a dud. thanks for the heads up on the s2emu1 I downloaded it last night so I could try it out, so it was handy. thanks for the help | ||
| | #5 | ||
| LoL ! so I've been loosing the little hair I have and the softc*am I've been using has not got the right k*ys in for C*nax! I deserve to be bald. big thanks I'll try 13 east while I wait for C*nax and the hair to grow back. Cheers | ||
| | #6 | ||
| Has the C*nax keys been updated in the softc*ms yet, their seems to be plenty about but none seem to give up the Kiosk or C*nel channels on thor. I don't know if it's my set up, or the keys I'm using, can anyone advise, cheers | ||
| problem, theatre |
Similar Threads | ||||
| Have a problem MPEG2 DVD conversion | mgharbawy | Computer Discussion | 4 | 21-06-2004 10:02 PM |
| Have a problem with Vision Plus | mgharbawy | Satellite PC Card Receivers & Internet by Satellite | 1 | 15-02-2004 10:47 PM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
| My Theatre Problem | arraknid | Satellite PC Card Receivers & Internet by Satellite | 3 | 25-08-2003 11:02 PM |
| Aston to Diseq poitioner problem | BazelAd | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 4 | 20-08-2003 07:21 PM |
