Watching Encrypted Channels with SkyStar 2
Old 28-07-2004   #1
Hi there...
Please I need your help , I need a program to Watch Encrypted Channels on Hotbird using Skystar 2 I am using DVBviewer Program .
please help me with this and I will be grateful for you
thanx..
issamh is offline   Reply With Quote
Old 28-07-2004   #2
BGonaSTICK's Avatar
Forget DVBViewer. Get ProgDVB or MyTheatre V2.76.
Really.
Old 28-07-2004   #3
Really.
I am trying to configure my ProgDVB but still having problems with SoftCAM. I am trying to run Fun2MD as per TED suggestion, but keeps on giving me the following error: "Component 'COMDLG32.OCX' or one of its dependencies not currently registeres: a file is missing or invalid" with just OK button. What must I do, just to be able to decrypt Nagravision for now?
adasil2002 is offline   Reply With Quote
Old 28-07-2004   #4
BGonaSTICK's Avatar
Hi, I'm real busy at the moment, but read some of the other threads re. Y*nkse. The Big Ted stuff is a bit out of date now, if I remember correctly.
If you're still stuck tommorow, I'll sort you out.
STICK
Old 28-07-2004   #5
rolfw's Avatar
Real name: Rolf
Fun to MD is great for converting 6-in-1 #eeproms, but to be quite honest, most files have a softcamkey included, you might as well use that.
Rolf
Old 29-07-2004   #6
As I told you Rolf, I am very new in this. So, I dowloaded some SoftCAM from the Web and put them into ProgDVB folder but nothing changed - when I am running the progDVB Program, under Plugins Menu comes nothing (I do not know if should come) and I still can not watch/Listen encrypted channels (Nagravision). Can you forward to me (directelly) the needed files and where to put them (procedure do use them). FTA are ok.
Regards,
Old 29-07-2004   #7
STICK
I'm still stuck... pls HELP
Old 29-07-2004   #8
Exclamation
I download ProgDVB Then what I should do to see encrypted channels
The Following User Says Thank You to issamh For This Useful Post:
naela_l@yahoo.com (28-07-2007)
Old 29-07-2004   #9
BGonaSTICK's Avatar
OK People, here is a real quick guide.
Join T*ecutters den. Get the web address from Nobbly's Big Links section on this forum.
Download the latest S*ftcam.key file from mach1 in the S*ftcam section there. Don't rely on any old versions. The contents change regularly.
Download and install ProgDVB (latest version) from wVVw.progdvb.com, or MyTheatre V2.76 from wVVw.sat.joy.ro/download.html.
Extract the S*ftcam.key file into the ROOT directory of ProgDVB (i.e. C:\ProgDVB, unless you changed it at install time) or MyTheatre (C:\Program Files\MyTheatre - probably).
Ensure that (for ProgDVB) in the same place is a file called MDWrapper.dll. This is just a wrapper for any MD compliant plugins used with the viewer app. and will allow you to access its parameters from the app. menu. Not sure if it comes with the ProgDVB program, but I know it comes with the MyTheatre viewer (... and you select it at install time). In MyTheatre, it goes in the 'Plugins' subdirectory.
Then go to y*ankse.dvbnetwork.com and get the latest 'common' files for the Y*nkse plugin. Now off to wVVw.y*nkse.com and the the latest version of the plugin .dll itself. Place all the Y*nkse files in the root directory of ProgDVB, or for MyTheatre V2.76, put them all in the 'MDPlugins' subdirectory.
That will do it.
If you want to watch the S*ca2 broadcasts from S*y Italia on Hotbird 13E, the rip out the Y*nkse stuff above, and replace it with a single .dll file called S2emu.dll. It's available from T*es. Get the latest version (V1.04 last time I looked).
Y*nkse doesn't work with S2 at the moment.
Don't think I've missed anything!
Enjoy.
STICK
Old 29-07-2004   #10
Download the latest S*ftcam.key file from mach1 in the S*ftcam section there. Don't rely on any old versions. The contents change ......................................
STICK
Thank you very much for your pacient answer. Meanwhile, I tried to Join the T*ecutters den but their site keeps on telling "Sorry, registration has been disabled by the administrator.". I believe that you may be registered over there...can you forward both files (S*ftcam.key and S2emu.dll) to me? FOR NOW I AM MUCH INTERESTED IN NAGRAVISION, IRDETO2, CRYPTOWORK and POWERVU.
Regards,
Old 29-07-2004   #11
rolfw's Avatar
Real name: Rolf
If Toecutters Den is closed for new members, then try Dean's Place (in Nobblys SAT Forum List) for anything DVB card related see also http://www.sat.joy.ro and navigate to Downloads.
PS. Forget PowerVu, Cryptoworks, Irdeto2 and the New Nagravision.
Rolf
Old 29-07-2004   #12
BGonaSTICK's Avatar
Regards,
See my PM.
Old 29-07-2004   #13
Something under Plug-Ins (Yankse)
Looks like I found something which added some items into my Plugins Sub-Menu. Should I set someting? can I find much higher version (Yankse) than 0.98? Thanks for all your help - tehre are some channels that do not open. Meanwhle, why should I always keep the "Setup4PC" running. As soon as I close it, the ProgDVB Stops too. Must I do something? My ProgDVB version is 4.26.4.
Regards,
Old 29-07-2004   #14
BGonaSTICK's Avatar
You're doing well, but the latest version of Y*nkse is 1.31.0.
Get it from wVVw.y*nkse.com.
Stop setup4pc running, by removing it from your Windows startup group.
Old 29-07-2004   #15
Smile
For those channels that come in RED (meaning there are coded) which do not play....when I open Plugins -> Yankse -> Show Monitor, comes a lot of Hexadecimal number at left botton of the 'dialog box' does it require my intervention, or I can not help at all? Is there something that I can do? It says that the System is Nagravision; key 00, etc....
Regards,
Old 29-07-2004   #16
BGonaSTICK's Avatar
No, nothing you can do other than plug keys into the s*ftcam. There is the potential of auto-update for keys on some N*gra channels, but I'm pretty sure that's not going to help you.
Looking through the S*ftcam file, the only 'extra' thing you are going to be able to open on the PAS 7/10 sats are the SABC channels (in N*gra) for which the keys should already be in your file (assuming you got the latest), but even those look like they haven't changed in over a year (since March 2003).
Welcome to our world!
Old 29-07-2004   #17
Is there a way by which I can see the keys covered by my S*ftcam file?
Old 30-07-2004   #18
Long Term Contributor
s*t*a*r*m*a*n's Avatar
I imagine you could use one of the many editors out there or you could just open the file in notepad i guess. if you cannot get it to open in notepad just hold down the right ctrl key and right click over file and you should see the menu with "open with" just click that and choose notepad or wordpad.
I would just like to say that it is possible to have the y*nktze files in the same folder as the S2*mu.dll without any problems and you can have them both activated. You do not have to untick any of the plugins in order for it to work. Some s*ftcam files will work fine on se*a 2 and others will not just try different ones
s*t*a*r*m*a*n is offline   Reply With Quote
Old 30-07-2004   #19
Thank you very much STARMAN. I should tell BGONNASTICK that I will be very happy if I can, at least, watch those SABC (Nagravision Encrypted) Channels. Up to now, the only step forward I had, is being able to have YANKSE under the PlugINS Sub-Menu. As far I could check (LyngSat), those other channels on PAS7/10 that ProgDVB detect as Encrypted, are open. So, I am still checking around to find some ?S*ftcam? or whatever which will allow me to watch those channels (will be like a million dolar gift ).
Old 30-07-2004   #20
BGonaSTICK's Avatar
Go here :- http://dvb.lv/index.php?showfilesfordate=All
and look for a file called Softcamkey 29-07-2004.zip posted by kaptan on the 29th July. It has your s*ftcam, and includes the codes for SABC.
You can Palpal me the million dollars when you have it
Old 19-08-2004   #21
Is there something which I can do to be able to watch Satellite TV, in my Home LAN, from another PC which does not have any TV-Card? Consider for that that I am using ProgDVB...
Regrads,
Old 25-08-2004   #22
try using latest version of skyview as this has md plugin for you to put your softcam keys and yanksee in it, and is actually the best software for skystar 2 and is made only for skystar 2.
This is what I currently use and strongly reccomend it to anyone who uses skystar 2.
phillipgolding is offline   Reply With Quote
Old 28-07-2007   #23
My System: technisat skystar2
Hi dear...
Please I need your help , I need a program to Watch Encrypted Channels on Hotbird and pas7,10 using Skystar 2 I am using DVBviewer Program .
thanx
naela_l is offline   Reply With Quote
Old 28-07-2007   #24
BGonaSTICK's Avatar
Blimey, is this thread still running?
Try the free (and excellent) AltDVB V2.2 with either vPlug V1.7.4, S2emu V1.28.1 or preferably both for good measure
IIRC some (free) versions of DVBViewer don't work with these ('MD compliant') plugins.
Some people swear by the Pro version, but I'm a tight so-and-so.
channels, encrypted, skystar, watching
Similar Threads
X Dream TV encrypted in Dreamcrypt net1 Daily Satellite and Broadcast industry News 1 13-01-2009 09:48 PM
new sex channels for the UK net1 Adult satellite channels 3 23-02-2004 11:04 AM
Erotika drop three channels net1 Adult satellite channels 2 17-10-2003 02:48 PM
Erotica channels launch. net1 Adult satellite channels 0 24-06-2003 07:38 PM
