ss2 and motorDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| loiterer Join Date: 31-12-1999 Location: York's
| My set-up is a 1m dish on a rotorsat h-h 100 motor. This goes into the receiver and I have a separate feed off the lnb for my skystar 2. I now want to drive the motor using the pc card via mytheatre, progdvb etc etc. Loop out of the receiver won’t work, will it? So do I need a switch box, if so which one? Got the right plugins etc, just cant figure the hardware? | ||
| "Speak softly and carry a big stick; you will go far." | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Are you wanting to be able to control the dish with either unit? Not sure whether a loopthrough would work for motor control, an A+B switch would obviously do the job, but would carry an insertion loss. | ||
| Rolf, The motor still needs to be controlled by either device, but not at the same time. I would be using one or the other. Could you recommend an a+b switch that would do the job please? | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | | ||
| | #5 | ||
Thanks Rolf, Just managed to get it moving through the loopout on my sammy. I should really always allow at least three days messing with a satellite project before asking questions ![]() That switch is less than half the price compared to some other sites Ive seen | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | To make life easy, always try and leave the dish on your due south satellite. | ||
| | #7 | |||
| Specialist Contributor Join Date: 28-06-2004 Location: southern england, Berkshire
My System: Technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky, Span 58W to 42e with trees bare! | I have eaxactly the same scenario but cant get th e LNB loopthru to work with motor! What wa steh trick and what software were you using for the motor moving?
| | #8 | ||
| @Rossy, The plugin I use is ss2diseqc17, this goes in mytheatre plugins folder. In the first instance I disconnected the receiver and tried to move the motor directly from the card. Once I got it working I tried the loop out et voila. Let me know how you get on ![]() P.S Make sure you update the synet.sys file in windows/system32/drivers | ||
| "Speak softly and carry a big stick; you will go far." Last edited by Pullet_Surprise; 08-08-2004 at 03:41 PM. | |||
| | #9 | |||
Hmm, Alas no success. Connected to Dish without loopthru and Progdvb works fine. ss2diseqc1.7 however even shows dish as moving but no dish movement happens.Weird. I have tried every permutaion possible (apart from the right one I guess) for configuring but still no movement. Tried Dixie as well and still the same result
| | #11 | |||
My System: Technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky, Span 58W to 42e with trees bare! | Pullet. I uninstalled everything and reinstalled and lo and behold one moving dish!!! Do you find that PrOgDVD gets a bit blocky after awhile or if you change channels frequently. Even on 19E or 13E with strong signals I find occasional blocking. I have pretty fast PC 3.06 so was just wondering if you experienced the same or is there something else in options im missing. Thanks again
| motor, ss2 |
