mytheatre.exe
Old 01-08-2004   #1
loiterer
Pullet_Surprise's Avatar
mytheatre.exe
Using mytheatre v2.76 when I shut up and exit the program it closes it but the mytheatre.exe is still left running as a process in windows xp task manager. I have to ‘ctrl alt delete’ and manually end the process before I can run it again or use eol? Tried reinstalling a few times.
Anyone else have this problem or know a cure?
"Speak softly and carry a big stick; you will go far."
Pullet_Surprise is offline   Reply With Quote
Old 01-08-2004   #2
BGonaSTICK's Avatar
I only get this if it crashes when I'm using it. From that point on, it will continue to run in the background (no matter how many times I start/stop the app.) until I kill it, or reboot. I sometimes end up with more than one copy executing at once.
Do you sometimes/often get a "MyTheatre.exe has encountered a problem and needs to close" message?
Old 01-08-2004   #3
I also installed Mytheatre. It is openning and closing normally. The only thing I find hard to do is include a new satellite (Pas7/10) to its predefined list of satellites so that I can watch some channels from there. Can someone help to solve that?
regards,
adasil2002 is offline   Reply With Quote
Old 01-08-2004   #4
loiterer
@bgonastick
Not just me then? Get a few error messages now & again, I guess v2.76 still has a few bugs.
Old 01-08-2004   #5
Looks like the Mytheatre 3.12 is there already...
http://www.dvbcore.com/MyTheatre.html
Regrds.
Old 02-08-2004   #6
Originally Posted by Pullet_Surprise
@bgonastick
I should tell you that it was ok for me as I could not open any channel. Now that I cofigured the DisEq for Pas7/10, even without putting any Plug-Ins, it is not openning the FTA channles - when I try so, it blocks (Stops from running - I must force its end). So, you may be right or there is something that I am missing too.
Regards,
PS. Even with the MT 3.12 version. Try the ProgDVB 4.26 - It is much easier to work with, even myself can help you installing that .
Old 02-08-2004   #7
BGonaSTICK's Avatar
@bgonastick
LOL, it's a case of "living with it" aswell, as the later versions are worse, and they're not even free!
I'm waiting for programs live alt-dvb and dvbdream to catch up in terms of stability, then I'll swap.
mytheatreexe
