Pri/\/\a Fila No More???
Old 04-08-2004   #1
Lucifer's Avatar
My System: Phoenix Apollo ci converted to OpenBox. Sky_star 2 PCI card. Nokia DBox2c. Sagem Dbox2c. 60cm Channel Master @ 28° ALPS LNB. 60cm Channel Master @ 19° Syntec 2000LNB. Diseq Switch. Panasonic TU-DSB30. Duolabs Dynamite & Cas2+ interface. Matri
Unhappy Pri/\/\a Fila No More???
Hi all, I've just noticed no Pri/\/\a Filas Are clearing on Sly Italia!!!! Is this just me or has something bad happened?? I've been using S2emu 1.06 for days and its all been clearing fine until now. Anyone else encountered the same?
Lucifer is offline   Reply With Quote
Old 04-08-2004   #2
Lucifer's Avatar
Angry Update
Some Pri/\/\a Fila'z high up in the 20's are clearing this morning, this is very strange.....
Old 04-08-2004   #3
rolfw's Avatar
Real name: Rolf
They're all clearing on the Dreambox, so can't be a key change.
Rolf
Old 05-08-2004   #4
Lucifer's Avatar
Question Update Pri/\/\a Fila'z
Hi again, I can curremtly only clear Pri/\/\a Fila 24,25,26 and 27, the info from S2emu says 0070 key 0C. The remaining Pri/\/\a Fila channels give no info in S2emu and do not clear as from around 3rd Aug (I've also reverted back to older softcam key just in case). All other channels clear ok. Could it be something to do with the ECM numbers? If so I can post the numbers if it helps. Thanks in advance for any help, Lucifer.
Old 05-08-2004   #5
BGonaSTICK's Avatar
Something has changed...
In addition to yours, I can also get 10, 28, 29 and 30, but missing some or all of the others.
I think a sat/transponder re-scan may fix it, but I've not got time to fiddle with it at the minute.
Can report though, that all still working on my Dreambox, so not key/nano etc. related. Must be an easy fix then!
Old 05-08-2004   #6
BGonaSTICK's Avatar
Originally Posted by BGonaSTICK
Something has changed...!
Just did a quick test on PF18, and performed 'Update from Sat' function in MT V2.76, and it was fixed, so suggest you just re-scan affected channels/transponders.
STICK
Old 06-08-2004   #7
Lucifer's Avatar
Thanks Stick, all sorted - it's easy when you know how! all clearing panic now over.
fila, pri or or a
Similar Threads
This Weeks XXX On Prima Fila 7-17 Dean131 What's on listings 1 29-05-2004 12:44 AM
Prima Fila XXX 28/05 to 04/06 Dean131 What's on listings 0 28-05-2004 05:12 PM
Prima Fila XXX 19th-25th Dean131 What's on listings 0 19-03-2004 10:50 PM
Prima Fila XXX 12th-19th Dean131 What's on listings 0 12-03-2004 11:11 AM
Prima Fila XXX Listings Dean131 What's on listings 0 09-03-2004 08:24 PM
