'Dancing box' screen bug?Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| has a Regular Member Join Date: 27-07-2004 Location: Czech Paradise
Hi there, after a few happy weeks with my SS2 and ProgDVB I've just started getting a strange bug on my screen. It's a group of 9 small white squares (the top right one has a dot in it) which flies around my screen a bit like a butterfly. It's pretty annoying and it happens on all channels. Has anybody seen this before or are there any ideas how to fix it, short of reinstalling? Weird!! I'm running XP, 1 gig RAM, ATHLON 200+, had no problems in the past... | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Try this thread Z3r0 http://www.satellites.co.uk/php-bin/...hlight=elecard | ||
| | #3 | |||
Problem is, it's still there... | |||
| Regular Member Join Date: 17-05-2003 Location: Washington Tyne & Wear
| ok m8 this should solve your problem..... do a search on your c: drive for this file " mpgdec.ax " and patch them all... you may find that there is other elcard video drivers on your system and your system may not be using the one that you patched.... best of luck...baz | ||
| | #5 | |||
Cheers ears | |||
| box, bug, dancing, screen |
Similar Threads | ||||
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Brand new box problem | bollywood | Sky Digital (BSkyB) and Astra 28.2 East General | 26 | 15-03-2004 09:21 AM |
| Does Sky digital box pick up channels after subscription is cancelled? | Rajitha | Sky Digital (BSkyB) and Astra 28.2 East General | 4 | 07-02-2004 07:54 PM |
| New box advice | cjgall | Sky+ (Plus) and PVR Systems | 15 | 18-11-2003 04:15 PM |
| Pioneer to launch Freeview digital set-top box | net1 | Terrestrial Television, Digital and Analogue | 0 | 08-08-2003 10:44 PM |
