ProgDVB Picture breakup
Old 21-08-2004   #1
My System: Technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky, Span 58W to 42e with trees bare!
Is it normal with ProgDVB to experience bad breakup of the picture even on strong signals from 13E and 19.2E. My PC is powerful enough 3.06 Processor but still get bad pixellationand video lag on most channels after a few minutes. Is there any Options/Settings anyone can advise to change to help eliminate the problem
Thanks for any advice
Cheers
rossy is offline   Reply With Quote
Old 21-08-2004   #2
BGonaSTICK's Avatar
Can be many things, but I found one that helped was having a big, fast, empty (de-fragged) disk, loads of memory, huge buffers and high CPU priority.
Old 24-08-2004   #3
Thanks apprecaite it. What size/where do you amend the buffer size?
Changed the Priority to realtime and less freeze already
Cheers
Old 24-08-2004   #4
BGonaSTICK's Avatar
I was referring to the timeshift buffer. Can't remember off-hand how to do it in ProgDVB, but in MT it can be setup/adjusted by right clicking the main window, then General Settings, click the timeshift tab, and set the location and size.
There is something similar in ProgDVB. Can't get on my ProgDVB computer to check at the moment.
Either set it up on the root directory of the disk, or beter still, have it in memory. I have mine set to 200MB size, and 4X recording speed (in MT). You can experiment with the latter to give best results.
Of course, a good graphics card also helps, and I think I remember people having problems with HyperThreading being enabled...
You could also try stopping any other programs and services running while you're using ProgDVB, esp. Anti-Virus software etc.
Old 24-08-2004   #5
Ex Arcade Bandit
prof's Avatar
Hi Rossy,
Click on settings > audio video > time buffer.
prof is offline   Reply With Quote
breakup, picture, progdvb
Similar Threads
HDTV Primer spiney High Definition Receivers transmissions, satellite and Terrestrial 0 16-01-2006 12:42 PM
progdvb & ss2 help andy-gi Satellite PC Card Receivers & Internet by Satellite 5 05-07-2005 06:24 PM
Progdvb Question? ripley607 Satellite PC Card Receivers & Internet by Satellite 1 02-03-2004 12:13 PM
ProgDVB and Multidec API darknebulae Satellite PC Card Receivers & Internet by Satellite 2 01-09-2003 11:01 AM
Sound / picture out of sync Pict Sky Digital (BSkyB) and Astra 28.2 East General 4 21-07-2003 01:58 PM
