PCI motorized system fail to work...asistence reqDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 04-09-2004
Help! There is no signal.. skystar2 PCI tuner moteck SG2100 motor fortecstar uni LNB 0.4 ProgDVB says: DVB Viewer: DVB receiver: There is power in the motor as I can operate it with the manual botton. LNB isnt defective as I tried allready with Sharp 0.7db and nothing changes | ||
| Ex Arcade Bandit Join Date: 23-02-2004 Location: In the spare room.
| Glarus, Have you set up your motor /dish correctly? www.satellites.co.uk/php-bin/forum/showthread.php?t=5474 Have you viewed any channels yet using your ss2? | ||
| Long Term Contributor Join Date: 01-05-1999 Location: scotland
![]() | Go to settings/DiSEqC then click on property and choose the satellite you are on such as hotbird then click ok then ok again then go to "channel list" then channel scan. hope this helps. if you are on the sat and receiving a signal then you should see channels being detected. make sure lmb power is on. | ||
| | #5 | ||
| Specialist Contributor Join Date: 24-07-2004 Location: Kent
| Dont forget my previous post on this, by using the drivers i uploaded I managed to fix the problem quickly, just remember to follow the instructions fully. Heres the link to my post: http://www.satellites.co.uk/php-bin/...ad.php?t=27506 | ||
| | #7 | |||
It definately works! | |||
| fail, motorized, pci, req, workasistence |
Similar Threads | ||||
| Official TD Image | Llew | Triple Dragon | 29 | 13-12-2007 04:56 PM |
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Lists of Software upgrade sites | jo_lb2002 | Receiver software, international Section | 17 | 23-11-2004 08:05 PM |
| What Modem Pci Card do Netsystems use? | Mr G | Satellite PC Card Receivers & Internet by Satellite | 1 | 06-12-2003 01:47 AM |
| gizlog1.3 and twinhan pci card | radiotech | Satellite PC Card Receivers & Internet by Satellite | 1 | 18-08-2003 08:47 PM |
