SkyStar2 CaptureDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Specialist Contributor Join Date: 24-07-2004 Location: Kent
I was thinking, is there any software available that lets you capture the complete stream from a transponder so that it could later be decrypted and split apart? A lot of PPV channels run on the same transponder, so you could just receive everything at once if you left it a few hours. And then it would save trying to record one thing after another. If there is no software, then I cant think of any reason why it would not be possible, although I am making the assumption that there is a constant datastream of all the channels data being multiplexed together, so a standard capture involves filtering one stream from the others. If they were all just left in tact then capturing would be quicker, meaning you would simply need to seaprate the streams in postprocessing and trim them up so that each file began at the start of the movie. | ||
| capture, skystar2 |
Similar Threads | ||||
| About SkyStar2 With B2C2 Shipset ......Question? | tabozada | Satellite PC Card Receivers & Internet by Satellite | 6 | 19-04-2006 10:03 PM |
| SkyStar2 - what channels on Astra 19.2E ? | Rod Hulls Aerial | Satellite PC Card Receivers & Internet by Satellite | 9 | 01-03-2004 09:08 PM |
| Watch Cryptoworks channels with SkyStar2 PCi | alexyug | Satellite PC Card Receivers & Internet by Satellite | 1 | 23-02-2004 09:45 AM |
| SkyStar2 what channels?! | FoneFreak | Transponders & channels | 4 | 20-09-2003 01:00 PM |
| Skystar2 locked or dead? | riddler2000 | Satellite PC Card Receivers & Internet by Satellite | 1 | 06-09-2003 07:14 PM |
