Any Plugin For Dvbdream And Prodvb?Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 10-09-2004
Hi, Any Plugin For Dvbdream And Prodvb To Update Key For Viaccess, Viaccess2, Irdeto, Irdeto2, Seca, Seca2 And Nagara Pls? I Tried With S2emu Its Update For Polysat Only. Fennrir Only Update Keys For 000b00 And 009400 Only And Others Yankse, Stinch No Any Update. What Type Of File/software Needs. Pls Help And Provide Information Etc. | ||
| Specialist Contributor Join Date: 28-06-2004 Location: southern england, Berkshire
My System: Technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky, Span 58W to 42e with trees bare! | You sure you got SOft***.key in place and teh latest version? as it all works for me | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | With some of the encryptions you mention, it won't matter which softcam or plugin you use, they are not hacked or do not have keys available.. | ||
| | #4 | |||
My System: Technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky, Span 58W to 42e with trees bare! | Rolf, Yes I agree. What I meant by ALL is that all that is possible to view can be viewed . Sorry for any confusion I caused. Cheers
| | #5 | |||
WHAT ARE "RSA KEYS" AND FROM WHERE CAN GET? BECAUSE ONE OF MY FRIEND TOLD ME THAT YOU NEED RSA KEYS. | |||
| | #7 | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | No S*CA 2 packages open ATM, but there are loads of others open. Biggest ones being Telenor on 1W, and TPS/Multivision on 13E. Loads of other bits and bobs open too including Polsat and ABsat. Keywise, for PC cards (RSA keys or not) all of them have to be decoded (plain) and be in the s*ftcam.key file. Download the latest mach1 file, and everything will be in there. No other file is required. | ||
| | #8 | ||
| Regular Member Join Date: 18-10-2004
| right lads..... prog dvb is running, i have yankse too but dony know what i can get and how to get it.... i have scanned all the transponders and have all available channels on 19.2 east but canal+ and premier etc is all there......cant see them though...... any help or anyone willing to help please pm me.... regards gordy! | ||
| | #10 | ||
| Member Join Date: 20-11-2004
| multivision is gone, i try updating the soft***.key. i have skystar 2, use progdvb & s2emu v1.08 it used to work i think they changed the codes but it doesn't seem that the .key files that i download contain keys for multivision could someone point me to where i could get keys for multivision | ||
| | #11 | |||
| ASBO Club Member - Persona non grata Join Date: 13-08-2004
| | #12 | ||
| Member Join Date: 11-04-2008 Location: yemen
My System: strong 4620x | Hello, can any one help??!! I'v kworld dvb-s 100 card and the disqu did not work with any dvb programs exept the (hypermedia) it's original program, i need to use programs like progdvb, deramdvb, to watch scrampled channles, so, i will be greatfull if anyone help me solve this problem. | ||
| dvbdream, plugin, prodvb |
Similar Threads | ||||
| Not getting encrypted channels with ProDVB | mustang67 | Satellite PC Card Receivers & Internet by Satellite | 0 | 10-07-2004 04:44 AM |
