Thor 1w picture problems/speedDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 01-09-2003 Location: top of flats, london
hi, Apoligises if my questions are dumb but i've looked all over the forum (promise) and i couldn't find any answers. I've a skystar 2 card on a p3 computer and my 80 metre dish is pointed to thor. Now i know that's not big enough to get private gold and a few other channels but i've had picture problems, but for example i read you can't see ki*sk because the picture breaks up as does the adult channel, bbc world etc using progdvb so i wanted to use alt dvb. On alt dvb on the kio*k channels alot of the time the channels come on but go off after a few seconds? anyone else have this problem? Also adult channel and some others (bbc world etc).. the sound cuts up and alot of the time the picture doesn't come on, though when it does the channels very slow. I'm using s2emu 1.08 by itself, anyone know if we can get these channels with a good picture on alt dvb or any other software and also would it help if i used a bigger dish? I do have a current softcam and using other software (progdvb) other channels don't seem to have a problem wanting to work for me -sighs-. If it helps i'm located in nw london Hope you guys can help me. | ||
| Regular Member Join Date: 13-11-2003 Location: KENT
| It could be that your processor is not fast enough - you need at least 800mhz to get a reliable result - although i am sure some people use a slower cpu and claim good results. I think ALTDVB in conjunction with S2 EMU is quite cpu hungry, so maybe try a different program. I use DVBDREAM, which gives me excellent results on Thor, with a 933mhx PIII, although i do have a 1M dish. Hope this is of use Peter in the Bus | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Kiosk worked just fine in DVBDream, ProgDVB and MyTheatre V2.76 on my P3 800 with a 70cm dish here on the sunny south coast. They obviously still work on my XP2500 with an 88cm dish Try my Skystar 2 tuning tips in another post on this forum. | ||
| | #5 | |||
| Will do pal.
| | #6 | ||
| The Lord Lucan Moderator Join Date: 15-01-2004 Location: The cold and foggy Yorkshire coast..
My System: Sky Star 2 - Motorised Errr.. thats it. | Hello Striker, I recently had the same problem, using DVB-Dream it works.. well like a dream actually !! And as others have advised Priv*te Gold is on a different beam on Thor not easily accessable from the UK so thats out for most of us. | ||
| What's got four legs and goes "shhhhhhhhhh"? Rod Hull's Telly...... | |||
| | #7 | ||
| cheers rod hulls telly. I managed to fix it so I can now watch bbc world in peace...:-) and dvvdream is good though i've not sorted out video properly yet because sometimes it's a black screen until I click on video and change internal to external graph but hey i'm not moaning. Thanks for all the help and advice | ||
| picture, problems or speed, thor |
Similar Threads | ||||
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Digital picture quality | Pullet_Surprise | Terrestrial Television, Digital and Analogue | 12 | 22-08-2004 02:03 PM |
| Picture Problem !!! | Malteser | Cams and decoders General | 2 | 29-02-2004 09:00 PM |
| Sound / picture out of sync | Pict | Sky Digital (BSkyB) and Astra 28.2 East General | 4 | 21-07-2003 01:58 PM |
| FTV Card - SKY 2nd Generation with a picture of a yellow house on it | ShayK | Sky Digital (BSkyB) and Astra 28.2 East General | 2 | 12-07-2003 07:52 AM |
