MT 2.76 Plug-ins
Old 12-11-2004   #1
Old Geezer's Avatar
Question MT 2.76 Plug-ins
Hi There,back again.
MT 2.76 all installed and working fine , but I could do with a bit of help on where to put the plug-ins.
I have downloaded S2emu 1.08 and am unsure where to stick it (dangerous question !!).
Do I extract ALL the files to the Root directory or just the softcam registry file.If so where do the others go (is it Plug-ins OR MDplug-ins).
I have tried this a few times and managed to get some channels decoded , but MT keeps throwing up errors , so as I extracted the file to ALL 3 locations suspect that it could be My doing.
Also when You use the updated Softcam key from HB , does it just replace the existing one (be it in root directory or wherever).
I have done a search on the forum , and the locations for placing files seems to differ for different viewers , so a bit of a guide would be helpful (and hopefully be of use to another beginner).
Thanks again All,
Cheers,
Old Geezer
Old Geezer is offline   Reply With Quote
Old 12-11-2004   #2
BGonaSTICK's Avatar
For S2emu V1.08, put everything in the MT root dir. except the S2emu.dll file.
That goes in MDplugins.
Nothing else goes in MDPlugins at all ATM.
Only one S*ftCAM.Key file can be used, and it goes in the root, as above.
The Plugins folder should contain MDWrapper.dll, SS2DiSEqC.dll and SS2DiSEqC.exe, plus the Satellites folder. The diseqc stuff will only exist if you're driving a motor.
Mach1 keyfiles are of very high quality, and are regularly updated.
Download a new one as soon as you lose a channel.
STICK
Old 12-11-2004   #3
Old Geezer's Avatar
Thanks BG (again),
Does the same apply if You added the Yanksee dll (to the MDplug-ins directory).
I did find that the latest Softcam key allowed the Multivisons to open (just in case anyone is interested).
I'll give it a go in a bit.
Speak to you soon again (cries of "Oh No" from the Mods !!)
Old 13-11-2004   #4
BGonaSTICK's Avatar
I believe that there is nothing that Y@nkse will open that S2emu won't (certainly nothing that I view, and none of the bigger open packages) but it's good fun to play with. The stream monitor is better than S2emu.
S2emu is faster and more stable.
If you want to play with Y@nkse, remove the S2emu.dll plugin (just the dll), and replace with (in the same directory - MDPlugins) Y@nkse.dll, Y@nkse.ini and Y@nkse.prv.
You can leave Y@nkse.ini and Y@nkse.prv in place when you put S2emu back, but remove Y@nkse.dll.
STICK
Old 13-11-2004   #5
Old Geezer's Avatar
Cheers BG,
All up and running OK , with no nasty errors.
At least now I've got a good starting point to work from , and can experiment with any k*ys/dll's etc.
I may even try another viewer , but think that MT2.76 is the one for Me.It's so easy to set up (with a bit of help for the extras) and easy to use.
Thanks again for all the help,
Old Geezer
Old 14-11-2004   #6
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
Originally Posted by Old Geezer
Cheers BG,
Old Geezer
Having seen this thread I decided to get my MT back up to standard, not having used it for a while as I am Dreanboxing.
Was easy and worked fine....just follow instructions from Stick..
T_G
I only believe stuff that comes straight from Mr. Horses mouth!
T_G is offline   Reply With Quote
Old 14-11-2004   #7
kalamar's Avatar
I run Yank-N-see and S2EeemU AND Feeeeener all at once with good luck and no problems.
kalamar is offline   Reply With Quote
276, plugins
Similar Threads
Plug ins for 7025 martinw01908 Dreambox7025 0 15-05-2006 12:57 AM
How do i install a plug in?? redone Dreambox General 6 19-04-2006 12:05 AM
VideoGuard king_owende Conax, Cryptoworks, Nagravision, NDS and Others 19 16-02-2005 06:48 PM
My Theatre 2.76 transponder lists refinechange Satellite PC Card Receivers & Internet by Satellite 2 10-02-2004 08:32 PM
FCC backs 'plug and play' net1 Daily Satellite and Broadcast industry News 0 15-09-2003 08:37 PM
