I have terrible picture quality, please help!Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| User without a clue Join Date: 06-11-2004 Location: Cairo,Egypt
Hi everyone, I'm using ProgDVB with a VisionPlus sat card and I'm getting terrrrrible picture quality - very annoying. When I use the software that came with the sat card the pic quality is fine, so I'm assuming everything is fine with my dish etc setup. Am I missing something? Are there codecs or any software I need to improve pic quality? Please bear in mind I'm new to all this and I need very simplified laymen's explanations . Thanks in advance for any help! | ||
| Ex Arcade Bandit Join Date: 23-02-2004 Location: In the spare room.
| Hi afrowoman Although not familiar with the visionplus, it would help to know what is wrong with the picture. Is it breaking up, or lots of lines and looks jagged, if the latter it could possibly be a codec problem. | ||
| Thanks for your reply Prof, the picture is breaking up into little squares sort of thing, and the audio is choppy - I don't quite know how to describe it. Everything sort of "cuts up". Sometimes the audio is out of sync with the picture. If I do need codecs, which do I need? Thanks very much indeed... | ||
| The only prob I had with codecs caused lines and jagged edges. You could try altering the time shift buffer. Go into settings>audiovideo>timeshiftbuffer and increase memory size. | ||
| | #5 | |||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! |
The card is not decoding fast enough, increase the memory and see if it makes a difference. | |||
| | #6 | |||
| | #7 | |||
Love to learn more about PCs and I have learned a lot here - they are a great bunch and I'm sure someone else will jump in and help. Hope it all works out for you. | |||
| | #8 | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | | ||
| | #9 | ||
| Regular Member Join Date: 28-03-2004
| I've the same card,,, and the same problem with ProgDVB... what I noticed that,, ProgDVB requires lots of processing power. I've P IV 1.6 GHz but i have the same problem if I try to watch a channel and work with some thing else like browsing a websie.. I recommend for you to use MyTheatre which is good enough to resolve all these problems | ||
| | #10 | ||
My System: Dreambox 7000, Skystar2 | Yes, I think MyTheatre V2.76 is better and more stable, but I've had ProgDVB working fine on various boxes, including a PIII 800 using the tuning tips above. STICK | ||
| | #11 | |||
| ASBO Club Member - Persona non grata Join Date: 25-10-2004
| | #12 | ||
| Thanks again everyone. I tried all the tips you gave me BgonaSTICK, and it does seem a bit better, so thanks for that I guess I'm going to have to give My Theatre a go. My video card is seperate Kalamar. Thanks everyone, I really appreciate your feedback. | ||
| | #13 | ||
My System: Dreambox 7000, Skystar2 | Good. Don't forget to up the priority of MyTheatre if you switch over, and make sure you only use V2.76. Later versions are rubbish. | ||
| | #15 | ||
| Long Term Contributor Join Date: 01-05-1999 Location: scotland
![]() | Hi afrowoman ![]() the directdraw in progdvb never worked for me either, i spent months trying to figure out how to boost the brightness in the picture and it is in file/property then choose the codec you are using probably the elecard mpeg 2 one and click it then go to settings tab and there you will find the brightness level adjuster, just adjust it for brightness then click apply to save settings. should give a better picture if you decide to go back to using it. It should run ok on free tv channels on a pentium 3 800 mhz upwards i think, any less ythan this and you MAY get blocky picture breakup caused by the processor bottleneck which means it is not processing the picture information fast enough and so the picture is broken as happens with progdvb if it lacks system resources. Particularly bad if watching ppv channels as it requires more system resources, some more ram can sometimes help but the processor speed seems to be more important with this software as regards the skystar 2 card anyway. | ||
| | #16 | ||
| hi starman what you're saying makes a lot of sense, it *does* work better with the FTA channels.. the strange thing is the original software that came with my satellite card - VisionPlus, works fine with no deterioration in picture quality. Anyway I've given up on ProgDVB and I'm going to try My Theatre. Will let everyone know how it all goes. Thanks very much indeed for your imput! | ||
| | #17 | ||
| Ok- here's the latest update - My Theatre verion 2.76 crashes on start up - lots of error msgs - version 3.20 didn't but then it's not free. Oh well, back to square one it is for me... | ||
| | #18 | ||
My System: Dreambox 7000, Skystar2 | You must get rid of all traces of the later version before you install V2.76. Especially the MyTheatre directory under "Program Files". | ||
| | #19 | |||
| | #20 | ||
My System: Dreambox 7000, Skystar2 | I'll be interested to see how it behaves itself. I don't know anybody that didn't dump that version and go back to V2.76. Most folks find that it crashes and/or screws up regularly, but I don't have any personal experience. Just that of helping a bunch of folks having probs. I found that the uninstall didn't work properly (with 2.76 at least) and I had to delete folders manually. I also found that if you then re-installed, it would NOT overwrite the existing files that it should have deleted when you uninstalled! Anyway, let us know how you get on with it. All feedback is usefull. Good luck. | ||
| | #21 | |||
By the way RitzDVB is working nice now too. | |||
| | #23 | ||
| Hi again everyone. My Theatre is working like a charm however I couldn't get verion 2.76 to work, it just kept crashing on start up - I deleted everything before instlaling it yet it continued to crash. Version 3.19 is working very well, however, some channels are not working such as XXL and I tried using Satdude's frequencies to watch FreeTV but it wouldn't work. I think I don't know how to get s2emu working - because when I open it, it's blank with no entries. I used MD wrapper. Any ideas? Thanks in advance. | ||
| | #25 | ||
| Hi again BG I searched all your posts but didn't find anything related to installing plugins for MT? My plugins worked fine in PrgoDVB - this is extremely frustrating. I made an MD directory and basically put everything everywhere - sort of trial and error thingie. MT is "seeing" Yankse and Fenrir as plugins but s2emu isn't working I think coz when I open MD wrapper it's blank - no entries. I feel stupid and I feel I've already taken too much of your time - sorry | ||
| picture, quality, terrible |
Similar Threads | ||||
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Receivers and picture quality on TV | emission | Digital systems | 0 | 08-04-2005 01:11 PM |
| Picture quality of SAT-TV compared to Cable TV | erik1 | Digital systems | 2 | 24-04-2004 08:50 AM |
| Picture Quality through a Quattro Scart Switch | georgekildare | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 1 | 30-09-2002 10:20 PM |
| Picture Quality Problem. | JCartney | Digital systems | 2 | 21-03-2001 07:32 PM |
