1 west infoDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 08-06-2004
hi all i live in lancaster (north west uk) and i have an 80cm dish with a basic monoblock. is it possible to recieve 1 west from my location and setup, or do i need a bigger dish and a better lnb thanks in advance for any infomation nuggnu | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Hi mate - it's the eternal how long is a piece of string question. It depends on the threshold of your reciever, if your dish is a very good one, (a good 80cm will keep up with a mediocre 1M) if it is damaged in any way, the quality of your LNB (same above applies) the length of your cable run and what you use to run it, and the weather. If you are on the edge of reception then you may loose enough signal not to see anytihng when it rains! All to be taken into account. But the best thing you can do at the moment is move the dish and have a look to see what you can find. Good luck L | ||
| Super Moderator Join Date: 24-08-2003 Location: Dublin....Ireland
My System: Dusty Dreambox 7000s, & Sky HD. | [QUOTE=Lancelot]Hi mate - it's the eternal how long is a piece of string question. It depends on the threshold of your reciever, if your dish is a very good one, (a good 80cm will keep up with a mediocre 1M) if it is damaged in any way, the quality of your LNB (same above applies) the length of your cable run and what you use to run it, and the weather. If you are on the edge of reception then you may loose enough signal not to see anytihng when it rains! All to be taken into account. But the best thing you can do at the moment is move the dish and have a look to see what you can find. Good luck I installed one last week 80cm Triax, but could only receive some ch on 1w. Could not get the Kiosk ones, had to change it for 88cm and everything was fine. Location was Wicklow, Ireland. | ||
| Happy Dreaming | |||
| Specialist Contributor Join Date: 29-07-2003 Location: Chorley, Lancs
My System: Innovative, Diseqc Motor, 80cm dish | I am in lancs and struggle to get some of 1w on rainy/cloudy days. I have a 80cm mesh dish and 0.6db lnb. hoping that moving to 0.3db with improve things, if not i gonna change my dish. whats better mesh or solid? | ||
| | #5 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Solid Frankly . | ||
| | #6 | ||
My System: Dusty Dreambox 7000s, & Sky HD. | Changing your dish would be better as you will still get 1w with 0.6db lnb. Go for 88cm or 1mt dish first and then add the lnb at a later stage. | ||
| info, west |
Similar Threads | ||||
| Eutelsat satellite WC full channel coverage list | Analoguesat | Jimbo's Football and Sport | 0 | 07-06-2006 11:27 PM |
| Live feeds May | Satdude | Transponders & channels | 32 | 04-06-2005 08:40 PM |
| Live feeds today 31.07.04 | Satdude | Transponders & channels | 0 | 01-08-2004 12:31 AM |
| Panasonic TU-DSB20 - HTV West | Swedish sam | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 1 | 20-09-2003 02:54 PM |
