DVB-S PCI CardDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 16-08-2004
I'm at the stage of buying a card now. But which one ? How does the SkyStar2 compare to the Nexus-S ? I like the idea of a hardware decoder to take some pressure off the CPU, but is it just as capable of software decrypting using Multidec ? Cheers, Allen | ||
| Regular Member Join Date: 24-09-2004
| I would go for the SkyStar 2, it is the best piece of equipment I have ever seen in my entire miserable life. I must clarify I have both, the nexus and the SkyStar 2. The advantage of the Nexus is that your CPU will be below the 2% of use while using the hardware mpeg decoder, but that is not a big deal if you have a good machine. On the other hand, if you have an NVidia FX video card you can use the proper graph and codec to take advantage of the FX decoding capabilities while using the SkyStar 2 (which is cheaper than the nexus), switching channels is a little faster with the SkyStar 2. Good luck. I | ||
| | #3 | |||
Thanks, Allen | |||
| The FX5200 will do most of the decoding work, freeing the cpu of a great deal of processing, you just need the proper graph and the mpeg software decoder. I use RitzDVB and DVB Dream and both work nicely. | ||
| card, dvbs, pci |
Similar Threads | ||||
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| What Modem Pci Card do Netsystems use? | Mr G | Satellite PC Card Receivers & Internet by Satellite | 1 | 06-12-2003 01:47 AM |
| SAt pci card ? ? ? | MasterAbacus | Satellite PC Card Receivers & Internet by Satellite | 3 | 19-09-2003 12:25 AM |
| Which DVB card? | alnitak | Satellite PC Card Receivers & Internet by Satellite | 4 | 26-08-2003 02:17 PM |
| gizlog1.3 and twinhan pci card | radiotech | Satellite PC Card Receivers & Internet by Satellite | 1 | 18-08-2003 08:47 PM |
