1 deg w problemsDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 19-09-2004
Is it just me or is 1 degree not working anymore with current soft cams? I have downloaded no end of current softcams but still no go.I am using a ss2 card with emu ver 1.08. If I look under info it says Key: 20, No key in Softcam. Its driving me mad. | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | I've posted a link to the valid key in the last day or two. Check it out in this section. Apparently, they're re-using an old one, but from when I don't know. | ||
| | #3 | |||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh |
Why dont you look here and use this nice little tool? Worked for me.... http://www.satellites.co.uk/php-bin/...74&postcount=1 | |||
| | #4 | |||
| | #6 | |||
Or just go get another S*ftcam file. There are loads about now. | |||
| | #7 | ||
| Member Join Date: 21-11-2004
| sorry to butt in here but i am new so new that i don't know how to start a new thread anyway i need some help or advice i am thinking about buying this product on Ebay personally i don't mind finding out for £1.50 | ||
| | #8 | ||
| ah just re read your post. I think it is a gizmo that stops the digibox from comunicating with sky the payment services. I guess they catch up with you eventualy but i dont know much more than that sorry | ||
| | #9 | ||
My System: Dreambox 7000, Skystar2 | If you browse the forum by section from the main index, you will see a 'New Thread' button at the top of the list. Just read the rules first, and post in a suitable section. Save your money. It's a scam. It will just 'backlog' your viewing bill, and Sly will then chase you for the money when it becomes 'unblocked'. There are different variations on this theme, but they all end up the same way. Nothing that good would cost £1.50. | ||
| | #10 | ||
| Damn!! What a ploker I am. Ive just sorted out my 1 deg w viewing problem. Sorry all....let me explain. Ive been messing around with multiple monitors using tv via vid S lead . Anyway I just got that old softcam by shadows which is known to be working but still no picture. Well i couldnt figure it out, then i noticed my pc speakers where turned down so i cranked them up and found that i had sound but no picture although even though the mytheatre contols were all showing. It was then that i twiged ...it was my graphics card settings they must have become switched back to mutiple monitors setting DOH!!! Switched it back and now have sound and vision. Thanks all for your help anyway. | ||
| | #11 | ||
| Regular Member Join Date: 21-10-2003 Location: Kent UK and Cyprus
My System: TM 6900 Combo Motorised 80cm + dual lnb in UK TM 1500 Motorised 80cm in Cyprus Pinnacle Showcenter 200 MR Reloaded Diablo 2.3 Hotbird 13E Astra 1M widebeam Astra 1H 1W T2 Beam 7E,5E,10E,16E,26E,33E,42E 4W,7W,8W,12.5W,15W All Ok with 80 | Thanks All Working for me now Used the softcam downloader Skystar2 + s2emu 1.08 + Yankse 1.31tt Cheers | ||
| | #13 | ||
| Specialist Contributor Join Date: 29-07-2003 Location: Chorley, Lancs
My System: Innovative, Diseqc Motor, 80cm dish | just no key 22 thats all, although i read somewhere that key 22 was posted on 'the jfk forum' but never heard of this place? edit: on toecutters now | ||
| | #15 | ||
| The Lord Lucan Moderator Join Date: 15-01-2004 Location: The cold and foggy Yorkshire coast..
My System: Sky Star 2 - Motorised Errr.. thats it. | Yep new Softcam is out, working lovely !! it contains quite a few conax keys so might be a bit more "sturdy" | ||
| What's got four legs and goes "shhhhhhhhhh"? Rod Hull's Telly...... | |||
| | #16 | |||
coz i havin problem where the picture isnt fittin the window 100% its all squashed? i am using alt-dvb as progdvb cant decrypt fast enough. any ideas? | |||
| | #17 | ||
My System: Sky Star 2 - Motorised Errr.. thats it. | Hi Homer, your not reffering to wide screen are you ![]() I'm using good ole Yankse with DVB Dream... I have just checked ProgDVB and that's also good with Yankse and S2emu. Do a re-boot of your PC and check your display settings for your Graphics card matey ? Also have you changed your graphs around prehaps ? | ||
| | #19 | ||
| Ah yes all back to normal :-) I used the download tool mentioned above by tg and it works a treat. The byksat is the only one that seems to do the biz. I dont konw much about softcam files but I always have a good look into them by right clicking on them selecting edit and then looking at the keys. Some of the softcams that Ive downloaded dont have many keys so Ive been wondering is it possible to just keep on adding the old files in there and making a super big softcam or is it unlikley that old keys would be used again? Is there a limit to how many keys could be placed in the softcam file? | ||
| | #20 | |||
Don't forget that your key file is a critical resource in the decoding, so you want it to be accessed quickly. Small files, with redundant (old and unused, based on your location) keys removed will be better than a huge farty file of phlegm. I'm just starting to keep old keys to try on a key change, but you can be sure that there are plenty of others doing this, so they'll be out that much quicker anyway. STICK | |||
| | #21 | ||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! | 1deg west gone black again 24/11/2004 Or is it just me? | ||
| | #22 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | No, gone for me as well. | ||
| | #24 | ||
My System: Sky Star 2 - Motorised Errr.. thats it. | I think this is going to go on and on.... until one of us gives up. 2108 update : key 21 now out ! please excuse my earlier negativity ![]() until tomorrow of course when it changes again... | ||
| What's got four legs and goes "shhhhhhhhhh"? Rod Hull's Telly...... Last edited by Rod Hulls Aerial; 24-11-2004 at 10:09 PM. | |||
| | #25 | |||
(hope there's some about!!!) | |||
| deg, problems |
Similar Threads | ||||
| Sky+ recording problems | pjb | Sky+ (Plus) and PVR Systems | 4 | 17-06-2004 11:46 AM |
| Problems.... | ZeeJay | Magic Module | 19 | 22-02-2004 01:27 AM |
| Problems with 30W Nagra? | rolfw | Matrix Reloaded, Revolutions and CAS interface | 0 | 29-09-2003 12:01 PM |
| Few people seek help for sex problems | net1 | The Meeting Place | 0 | 22-08-2003 08:11 PM |
| Problems... Help ! | iwearflares | Analogue systems | 2 | 11-08-2003 08:01 AM |
