DiSEqC plugin,What is the best one?
Old 27-11-2004   #1
kalamar's Avatar
Hi
I am wondering what DiSEQc plugin you are using with ProgDVB and MT 2.76 ? I just took down my Triax 110cm dish and put up a new Patriot 90 cm with a new SG-2100 motor and dont really care much for the plugins I have now.Is there a BEST one that works good (best)? Also do you think the Triax 110 cm is too much for the motor ? I would rather use the Triax because my Maxi block lnb holder (4lnb's)will fit it without modification.I hate to "file down" the fittings to make it fit the Patriot dish. Does anyone know of a "stand alone" DiSEQc program that runs in Windows,just for setting the motor that can be used just for positioning the dish only ? need some ideas please. I used to have a Coship 5300 that I used with an SG-2100 motor but now want to use it on my Nexus-S
K
kalamar is offline   Reply With Quote
diseqc, plugin
Similar Threads
What is DISEqC 1.o ??? MasterAbacus DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 11-03-2007 07:12 PM
Help needed with My Theatre & DiSEqC switch please davie DISH SETUP: Single sat, Multi-Sat & Motorised systems 9 19-03-2004 07:34 PM
Antenna Feed switches: 12V & Diseqc jeallen01 DISH SETUP: Single sat, Multi-Sat & Motorised systems 3 16-02-2004 11:56 AM
is this a diseqc problem doggy DISH SETUP: Single sat, Multi-Sat & Motorised systems 14 05-09-2003 02:44 AM
diseqc motor & Echostar problems - HELP! css_jay99 DISH SETUP: Single sat, Multi-Sat & Motorised systems 0 25-06-2003 02:35 AM
