Removal of existing Technisat DVB viewer Software before downloading ProgDVB?
Old 02-12-2004   #1
Markie9999's Avatar
Unhappy Removal of existing Technisat DVB viewer Software before downloading ProgDVB?
Hi all, sorry for such a basic question but have just started with DVB-S today! I have just insatlled Skystar 2 card (no dish or LNB yet - I know, I know). If I want to install ProgDVB do i need to uninstall the current Technisat DVB viewer software or can I just download ProgDVB?
Many thanks (and grovelling apologies for such an ignorant question!).
Markie9999 is offline   Reply With Quote
Old 02-12-2004   #2
BGonaSTICK's Avatar
No need to remove it, but you may find yourself juggling with codecs the more viewers you install. Play it by ear, but there are no application conflicts AFAIK.
Old 02-12-2004   #3
Jaffer's Avatar
My System: Samsung A300W with component output Hotbird & Astra2
Hey, Dont uninstall DVB viewer software. I made this mistake and took hell of time to fix the problem. If you read some of my old thread you will know. You can load ProgDVB as it is. Take care.
Every little helps and a little help goes a long way!
Jaffer is offline   Reply With Quote
Old 02-12-2004   #4
Markie9999's Avatar
Thank you very much BGonaStick and Jaffer I shall try it tonight - unfortunately still on 56Kb modem so shouldn't take longer than four hours to download ProgDVB!
Old 02-12-2004   #5
BGonaSTICK's Avatar
NP.
It's not very large (1.76MB).
You can uninstall DVBViewer as long as you don't uninstall the drivers, but it can be a bit tricky.
Old 02-12-2004   #6
Markie9999's Avatar
Thanks very much Llew and BGonaSTICK, t'is much appreciated.
One stupid question, how do I install Yankse in the ProgDVB directory, is it a matter of copy/cut and paste or do I need to unzip/activate it in some way.
Also I seem to recal a previous thread which talks about updating the root directory/bios is this necessary.
Many thanks and apologies for ignorance!
downloading, dvb, existing, progdvb, removal, software, technisat, viewer
Similar Threads
NOW you can turn your receive super to ultra enter here jack0 Receiver software, international Section 364 17-11-2008 12:26 PM
Transponder update October 2007 Satdude Transponders & channels 666 25-10-2007 11:44 PM
New software upgrade for Thomson/Grundig receivers - 3/07/03 net1 Receiver software, international Section 6 08-06-2007 06:18 PM
Microsoft Pre-release Software License Terms Satdude Daily Satellite and Broadcast industry News 2 26-04-2006 03:56 PM
Progdvb Question? ripley607 Satellite PC Card Receivers & Internet by Satellite 1 02-03-2004 12:13 PM
