In Process of Setting Up Skystar Satellite System - HELP!Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 02-12-2004
| Hi all, I am in the process of setting up my Skystar 2 card and have installed it with the Technisat software I downloaded from their website (card did not come with any software). My setup is: Intel Celeron 2.7GHz Processor 256MB RAM 3D On Board Graphics (64MB) - no AGP slot on the board (boo hoo) 19" Iiyama Monitor (CRT) Skystar 2 PCI card (v. 2.3?) Soundblaster 5.1 Live Digital Soundcard Windows XP Service Pack 1 Internet Explorer 6 Media Player 9 DirectX 9c Technisat DVB viewer (TE?) with PVR I want to download ProgDVB and Yankse, is there anything I should do before I attempt this (apart from install the LNB and dish which are on order!). Very many thanks from a green member. | ||
| | #3 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed |
Nothing to stop you installing ProgDVB now, just put the Yankse in the ProgDVB folder. Or you could try S2emu. You'll need the latest softcam file when you're up and running. Not much else you can do until you have your dish installed. Llew | |||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Don't want to be negative, but you may find that your graphics chipset might not give you great results, so be prepared. It might also be fine You can tweak the performance of the SS2 setup simply by optimising everything around it. See one of my older posts on this subject. Also, you might find that one of the earlier driver versions works better, but only try this if you have problems. PowerDVD version 5.0 is a good addition for playing back recorded files, and will play stuff that WMP9.0 doesn't like. It also contains some good codecs. If you're going to install this, do it before you install your sat-viewing software. Definitely go for S2emu as opposed to Y@nkse. STICK | ||
| | #6 | ||
My System: Dreambox 7000, Skystar2 | More stable, faster channel switching, better support, Auto Update on Nagra built-in, used to do S2 where Y* didn't (but now gone obviously). | ||
| | #7 | ||
| Thanks BGonaSTICK, any ideas which is better for Hotbird and Astra 1 satellites? Also, anyone know what the elevation angle is for a) Hotbird 13E and b) Astra 1 (19.2E). I will have a compass and satellite beeper to help me! Many thanks. Markie. | ||
| | #8 | |||
Find out your coordinates from:- http://www.heavens-above.com/countries.asp A useful site for calculating your angles is:- http://www.smw.se/smwlink/smwlink.htm Hope this helps Llew | |||
| | #9 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | ...and check out the excellent advice provided by T24 in the tutorials section of this Forum. | ||
| | #10 | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Hi Markie 9999 - Used to run an AMD K6 3-400mhz with 196mb ram and a 16mb graphics card it could (and still can) clear all available channels. but not quick enough to rec to HD. Try it - you cant break it, and there are people here who have been there. L | ||
| | #12 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | You're welcome mate. The spirit of experimentation and finding out what works well, is the main part of what goes on here. | ||
| | #14 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | I only said the 'main' part .. L | ||
| process, satellite, setting, skystar |
Similar Threads | ||||
| R.R. Satellite Communications Ltd with Viaccess | net1 | Daily Satellite and Broadcast industry News | 2 | 13-03-2009 01:56 AM |
| please help me upgrade one EUROSTAR Eurobox-9700 | gsmsikar | Receiver software, international Section | 9 | 09-09-2006 04:27 PM |
| Lists of Software upgrade sites | jo_lb2002 | Receiver software, international Section | 17 | 23-11-2004 08:05 PM |
| International News 14th January | net1 | Daily Satellite and Broadcast industry News | 1 | 08-05-2004 02:11 PM |
| Sky Guide Clock Setting | spud1962 | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 5 | 25-10-2003 01:52 PM |
