NEXUS-S DiSEqC problem
Old 13-12-2004   #1
Have problem with DiSEqC.
I can move dish with STEP N WEST or EAST.
GOTO angle or stored position not work.
It worked from the beginning but stoped after fist week.
Another problem, started about same time:
To have synchronized signal from same transponders
it is required to reduce frequency by 250.
Any ideas?
I have WindowsXP, Hauppauge NEXUS-S 2.2, driver 2.17g,
Moteck SG2100 HH motor, ProgDVB, HispaDVB, etc.
kostano is offline   Reply With Quote
Old 13-12-2004   #2
rolfw's Avatar
Real name: Rolf
For the transponder problem, check your LNB settings, if you have a universal LNB, they should be 9750 and 10600.
For the dish movement problem, check that you have your coordinates set correctly.
Rolf
Old 01-07-2005   #3
My System: Athlon 2400 Nexus-s Progdvb sg2100
Question SG 2100 Reset
I have the Same set up you have. About once a week I have to put put the SG2100 back to zero using the manual button and then re-set the motor using the re-set button. I used to program every thing from scratch, ProgDVB,DiseqcU,sat positions,ect, once a week but I soon found out all I had to do was put the motro back to zero and hit the re-set and every thing was ok for another week or so. I discovered that when the motor will not move on a channel change I can go into ProgDVB and use the positioner option and move the motor that way but in the end I still have to put the motor back to zero and hit reset. I have tried to fix this for the last 8 or 9 months, have read a lot of post's but never found an answer yet. If you have fixed yours, could you post it.I have just joined this site today an this is my first post.Missey
Missey is offline   Reply With Quote
diseqc, nexuss, problem
Similar Threads
Diseqc Switch to 2 dishes problem slayter DISH SETUP: Single sat, Multi-Sat & Motorised systems 7 26-08-2005 06:24 PM
Diseqc problem with Manhattan DSR 2500 APCI moordown66 DISH SETUP: Single sat, Multi-Sat & Motorised systems 5 12-06-2004 04:19 PM
Antenna Feed switches: 12V & Diseqc jeallen01 DISH SETUP: Single sat, Multi-Sat & Motorised systems 3 16-02-2004 11:56 AM
Have a problem with Vision Plus mgharbawy Satellite PC Card Receivers & Internet by Satellite 1 15-02-2004 10:47 PM
is this a diseqc problem doggy DISH SETUP: Single sat, Multi-Sat & Motorised systems 14 05-09-2003 02:44 AM
