Help again pleaseDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 16-12-2004 Location: Doncaster
My System: DM7020-S 88cm Triax Dish 1.8m Channel Master soon to be installed |
Hi I have had to reinstall Win XP due to the problem as seen here:- http://www.satellites.co.uk/php-bin/...ad.php?t=32301 The problem I have is that a Sat Man is due any moment to re-align me to 1W, so what I want to know is there a quick program I can install to see if I am locked on to 1W ? Cheers 4 any help. | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Not really, but he won't need that to re-align you if he knows what he's doing and has got a decent meter and/or FTA box, so don't panic. If he doesn't, then sack him. | ||
My System: DM7020-S 88cm Triax Dish 1.8m Channel Master soon to be installed | TBH, didn't instill me with confidence and am doubting weather he has done it right. Hope I'm wrong. | ||
| | #4 | |||
| | #6 | ||
| Super Moderator Join Date: 10-12-2004
![]() | Hi djc, if you've got access to an old analogue box then you could test it using the d2mac channels that are still left on Thor, if you get the scrambled d2mac showing up on TV3, then your dish is at least pointing in the right direction, even though you will be unable to test the signal strength. TV3 11.341 V I hope this is of some use. | ||
