LNB Setting for Thor 2/3 1W ?Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 16-12-2004 Location: Doncaster
My System: DM7020-S 88cm Triax Dish 1.8m Channel Master soon to be installed |
Need this info so I can use Setup4PC to add 1W as a Sat, so can test signal. Cheers | ||
My System: DM7020-S 88cm Triax Dish 1.8m Channel Master soon to be installed | Cheers, but just struggling to do a clean install of Win XP, I've installed it several times and cant seem to find the option of deleting previous installs. Its been a bad day. | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | LOL, If you were doing a clean install then a disk format into NTFS file format would be a good place to start. Keep going. Pain is outweighed by eventual success. Promise! | ||
| 2 or 3, lnb, setting, thor |
Similar Threads | ||||
| SS2 card Jumper setting ? | bobit | Satellite PC Card Receivers & Internet by Satellite | 5 | 14-08-2005 07:33 AM |
| setting up a used H-H mount | Sat_Crazy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 9 | 21-02-2004 10:57 PM |
| Setting up motor | Sab | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 16 | 11-02-2004 11:00 PM |
| Setting digibox for BBC FTA? | psbcn | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 6 | 15-12-2003 12:41 PM |
| Sky Guide Clock Setting | spud1962 | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 5 | 25-10-2003 01:52 PM |
