How can I test my aligned dishDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 16-12-2004 Location: Doncaster
My System: DM7020-S 88cm Triax Dish 1.8m Channel Master soon to be installed |
Just had the dish re-aligned, but cant get any of the DVB programs to work for some reason. Is there any other way to check to make sure its aligned properly ? Cheers | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Keys have changed, so only two or three channels will open, but you should get a signal indication. 11421Mhz, 24.5Msps Horiz is Kiosk1 FTA, so try that. Forget setup4PC as I don't think that it will find a data lock on 1W. Try MT 2.76 or ProgDVB, but the latter does stuggle with Kiosk for some reason. | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Hi mate - that's pretty much it. Although I hear that keys for that provider are coming through in matter of several hours rather than days or weeks at the moment. In the interim, make sure your setup is peaked to max (i'm sure he was a professional but it is a Saturday afternoon and fairly cold in the UK) And make sure your external eqpt is wintered properly (grease tape etc). by the time that's done you can look again. L | ||
| aligned, dish, test |
Similar Threads | ||||
| Test file Attachments. | chris | Test Area | 4 | 06-04-2004 11:33 PM |
| test | Schnuffi | Test Area | 5 | 19-03-2004 10:07 PM |
| Euro1080 test transmissions | gcohen | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 09-03-2004 08:38 PM |
| Test | Razor | Test Area | 1 | 17-11-2003 12:45 PM |
| Transponder update 17/10/03 | Satdude | Transponders & channels | 0 | 17-10-2003 08:41 PM |
