Nearly there...Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 16-12-2004 Location: Doncaster
My System: DM7020-S 88cm Triax Dish 1.8m Channel Master soon to be installed |
Right, installed DVB Dream and found out that the Sat Man had done is job right and aligned me to 1W After doing a complete re-install of, well everything and running all updates available to Win XP and installing the latest Power DVD Software, I was able to view the Kiosk 1 as suggested by BGonaSTICK, but the next problem I have is that the picture quality is fairly poor. I don't know if I need to amend any settings or install anything else as I have just installed the main proggy ? At the bottom of the screen the figures are, level = between 50-60% for and 100% for quality. When I tried it last night on Eutelsat W3, the picture quality was fine. Also worth mentioning that now the Software seems more resource hungry ? BTW, when are the new keys available so I can start enjoying a bit more than previews and what other essentials do I need to install for this. Cheers | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | You can play with 'graphs' and codecs, as well as trying my tuning tips for PCI cards. Seach this section for it. Scrambled channels will gobble more CPU, especially when you're trying to decode them. 60% signal is plenty good enough. Get yourself a copy of S2emu V1.0.9.1 and the latest s*ftcam.key file. That's it. Search my posts here for how to install them if it's not obvious. Good luck. New keys should be out in a day or two, and may last for the same period. Check here, and get them from one of the places listed in Nobblys big links section. | ||
My System: DM7020-S 88cm Triax Dish 1.8m Channel Master soon to be installed | Just installed MT 2.76 and the picture quality as improved greatly. But I still get a bit of sticking every so often, I have checked CPU usage and its not overloaded, so any other suggestions ? Cheers | ||
My System: DM7020-S 88cm Triax Dish 1.8m Channel Master soon to be installed | Sorted the sticking issue, by altering the Graphs from Win XP V-Sonic FX to the Win 2000 FX in MT2.76. Didn't see this option in DVB Dream so don't think I am going to be able to use that. How come the 2000 works best when I run Win XP ? Cheers | ||
| | #5 | |||
Bump your CPU priority for MT to 'real time' for extra zip. | |||
