TV Out by Graphics Card ?
Old 19-12-2004   #1
djc
My System: DM7020-S 88cm Triax Dish 1.8m Channel Master soon to be installed
Has anyone managed to do this and if so by what connection ?
I have a FX5600 XT and there is a DVI and S Video connector on the Card, but have just purchased a S Video to S Video and have just found out it won't fit the S Video on my Graphics Card
So what do peeps do to pipe to the TV ?
Cheers
djc is offline   Reply With Quote
Old 19-12-2004   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Cheers
What connector is on your card? If it isn't a Mini-Din you can usually find a cable to convert it for your TV. Or make one up yourself with various adaptors.
Llew is offline   Reply With Quote
Old 19-12-2004   #3
djc
Sorry, posted this in wrong section by accident. Please could you move it to the PC Card Systems section, or shall I delete it and repost ?
Not sure what connector is on the Card, the strange thing is, is that next to the port it reads S Video
Cheers
Moved to computer section - Llew
Old 19-12-2004   #4
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
It is Done
L
Lancelot is offline   Reply With Quote
Old 19-12-2004   #5
Llew's Avatar
Originally Posted by Lancelot
It is Done
L
I thought it more apposite to stick it in the computer section Lance, as it is concerned with the video card. Not to worry
Old 19-12-2004   #6
Lancelot's Avatar
Sorry Llew,
Just read his Req & shifted it.
Should have thought about the best place for relevant responses.
Old 28-12-2004   #7
farr's Avatar
My System: Windows XP Professional, Skystar 2, TM5200D+ Super, 1m motorised dish [62E-58W]
Probably a S-Video shaped socket but one that takes a non standard S-Video plug. Some Radeons for instance have 7 pin sockets that take audio and composite video out of the same 7-pin connector. The reason for audio is quite obvious; the reason for composite video being output by a dedicated pin rather than a convertor less so - the composite feed when output this way is allegedly cleaner than if converted by a S-Video to composite video convertor. Some of the pin outs described here www.digit-life.com/articles2/radeon-tv-out/ may be useful.
farr is offline   Reply With Quote
Old 02-01-2005   #8
djc
Thanks for that link. I now know I need to a 7pin to 4pin S-Video Cable or converter.
Cheers
Old 12-01-2005   #9
djc
After a bit of searching the best thing I can come up with are the following:-
Ebay.co.uk/ws/EbayISAPI.dll?ViewItem&rd=1&item=6734277660&ssPageName=STRK:MEWA:IT" target="_blank">http://cgi.Ebay.co.uk/ws/EbayISAPI.d...e=STRK:MEWA:IT
and
Ebay.co.uk/ws/EbayISAPI.dll?ViewItem&rd=1&item=5742517186&ssPageName=STRK:MEWA:IT" target="_blank">http://cgi.Ebay.co.uk/ws/EbayISAPI.d...e=STRK:MEWA:IT
I have the composite socket on my TV, so should these be ok ?
Would rather have gone for S-Video to S-Video, but can't seem to find a 7pin to 7pin or a 7pin to 4pin converter.
Cheers
Old 12-01-2005   #10
Hello,
I have a FX 5200 with TV out through S-Video, I purchased at Radio Shack a RF Modulator and this is what I do for watching movies in my old TV :
I connect an S-Video cable to the Video card TV out and a standard audio cable from the computer's Line Out to the RF modulator, the RF modulator is connected through a coaxial cable to the TV.
I also owns a FX-5700 and the card came with a special connector for Video In and Video out through S-Video or composite. I haven't tried to connect it to my TV yet.
The following product looks interesting:
http://www.aver.com/products/comptv_AVerKey550.shtml
P.S.
The RF Modulator is a small box used to connect a DVD or any video component to my TV.
Ghost_inside2003 is offline   Reply With Quote
Old 12-01-2005   #11
djc
Hi
I have a FX5600 and it only has the 7pin S-Video connector, the 4 pin cable is not compatible.
Also mine didn't come with that converter you mentioned on your FX5700 and don't know where I can find one either.
Cheers
Old 12-01-2005   #12
farr's Avatar
Hi
I've found one on Ebay Bad news is it's in the USA Here's the link to the adapter: Ebay.co.uk/ws/EbayISAPI.dll?ViewItem&category=41993&item=6735839865&rd=1&ssPageName=WD2V" target="_blank">http://cgi.Ebay.co.uk/ws/EbayISAPI.d...sPageName=WD2V
I know how easy it is to get hold of the composite convertors - I used to sell them on Ebay - but getting hold of the S-Video leads is a nightmare. One thing that *might* work in your case, if you're willing to risk it, is to break of the plastic tab on the S-Video plug that is just below the 4-pins. This can often stop the S-Video lead going into the S-Video socket on such non-standard connectors. At your own risk but if you have an S-Video cable lying around doing nothing it might be worth a try....
Old 13-01-2005   #13
djc
Found one of those from a uk supplier, it was listed under ATI graphics card in Ebay.
Also ordered a Composite Video Cable as well.
Thanks anyway.
Cheers
Old 15-01-2005   #14
djc
Managed to get a cable and got it working, only problem is its in Black&White.
Any ideas how to get colour ?
Cheers
Old 15-01-2005   #15
Lancelot's Avatar
What TV card / S/ware are you using there to generate the images ??
L
Old 15-01-2005   #16
djc
The graphics card is a Nvidia FX5600, all images are B&W.
Cheers
Old 15-01-2005   #17
Depending on the TV Out chipset of your nVidia card, do an internet search for "TVTool" which has been recommended on here before.
I had a similar problem with a Riva TNT2 card and this software solved it.
Got to "Adjust", "More Options", "Colour Carrier" and then move the fader. I brough my carrier down to -61 and it seemed to do the trick.
Good luck and let us know how you get on.
mr_boyson
mr_boyson is offline   Reply With Quote
Old 15-01-2005   #18
djc
Cheers4 that will do.
Will let you know.
Cheers
Old 16-01-2005   #19
djc
Just to let you know TV Tool didn't help. Going to look into the option of Streaming over LAN to XBOX.
Cheers
Old 16-01-2005   #20
Cheers
Let us know how you get on with the streaming
Did TVTool recognise the TV-Out chipset of your graphics card?
Old 16-01-2005   #21
djc
Yeah it recognised it, but couldn't alter the colour from B&W (more of a murky colour or non lol).
Will keep you posted on the Streaming.
Cheers
card, graphics
Similar Threads
Matrix Reloaded How To by AHAC rolfw Matrix Reloaded, Revolutions and CAS interface 52 27-12-2005 12:02 PM
BBC (Sky) FTA Card What card does what ? ShayK Sky Digital (BSkyB) and Astra 28.2 East General 5 26-01-2005 06:42 PM
Pentamedia card not initializing s*t*a*r*m*a*n Computer Discussion 1 14-07-2003 05:07 AM
