Does Skystar 2 really not support 4 LNB???Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 09-12-2004
this was the main thing why i bought this card, even 2 of them and now recently I have heard that you cant use more than 1 LNBs? talk about long lost hours of trying grrrrr | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | No, I'm saying that it can switch between 4 distinct LNB's, regardless of whether they are on the same dish or not. I am ALSO saying that INSTEAD of doing that, it can drive a motor. Either/or. STICK | ||
| | #5 | ||
| ok great... so all I need is to find this 1.1 DisecQ plugin, (not 1.2) and then I can use all the 4 LNBs to scan each satellite? But how will I see once the plugin is working.... cus I can already now select "1.1 or 1.2 DisecQ" with DVBprog | ||
| | #6 | ||
My System: Dreambox 7000, Skystar2 | The Skystar2 card already supports diseqc 1.1 out of the box, and will do the switching for your 4 LNB's without any further plugins. You only need the diseqc 1.2 plugin if you have a motor. STICK | ||
| | #7 | ||
| ok, thanks. that sounds good, and also what I hoped for. but I still cannot configure it properly to scan all the satellites... I can only find Astra channels. So is there something I need to manually do in the software so it it understands I want to scan on those other LNBs... I have treid so many different alternatives and searched on the web but cannot find any help regarding this matter still using DVBprog and also DVBdream but with the Dream I cannot get any picture | ||
| lnb, skystar, support |
Similar Threads | ||||
| Conax plans to set up unit to support CAS in India | net1 | Indian Subcontinent General Section | 6 | 17-08-2006 05:52 PM |
| Freeview manufacturers may not support 7-day EPG | net1 | Terrestrial Television, Digital and Analogue | 0 | 23-01-2004 08:43 PM |
| Skystar 2 | Homebrew | Satellite PC Card Receivers & Internet by Satellite | 5 | 09-01-2004 10:34 PM |
| Best video qualtity, Skystar 1 or 2? | mtiller | Satellite PC Card Receivers & Internet by Satellite | 13 | 03-12-2003 09:30 PM |
| Skystar 2 not working properly | ckrys1 | Satellite PC Card Receivers & Internet by Satellite | 11 | 31-10-2003 10:54 PM |
