Fujitsu/Seimens PC CardDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 11-12-2004
I have this card and use TT 2.17 drivers to install it. Everything is set as required, but still have a problem. Using any of the s/w cams I can't get the channels to clear unless I do a channel scan on one of the transponders. Its like this, I scan all the transponders using progDVB and get all the channels and s*emu works. Now, if I close progDVB and come back to it later the channels don't clear until I do another transponder scan. Seems to me that it may be the card drivers. I've tried all combinations of DVB progs and s/w cams and only have success with progDVB and s*emu. When I look at the s*emu monitor window it says "autoupdating" and appears to be hunting for something. Its as if it can't detect the encryption system, this is why I think its the card drivers. Anyone had a similar problem?? Cheers jonbhoy | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Sorry, I don't know your card, drivers etc. but if the monitor says 'autoupdating' and you're on a Nagra channel, then maybe it's trying to update your s*ftcam.key with the latest key. Make sure it's in the root file of progdvb, and maybe try a different key file. You need to give it a minute or two to decode the key and save it. Also make sure you're on S2emu V1.0.9.1. | ||
| BGonaSTICK, thanx for the reply much appreciated. I think you're right about the autoupdating trying to write to the cam file. I don't know why its doing this though, becuase it already has the right key. As i said it behaves as though its trying to detect the wrong encryption system e.g. sometimes I see Irdeto key 75 appear in the info window even though its a FTA channel. The only encryption from the provider is nagra, so it can't possibily have irdeto or can it??. The card is the same as Technotrend Premium or SS1 hence the TechnoTrend drivers. I think i'll give the SS1 drivers a go and see what happens. cheers jonbhoy | ||
My System: Dreambox 7000, Skystar2 | Have you got the very latest nagra files? Which channel/package are you trying? There have been many changes of late. Also, the S2emu monitor window can produce some spuriuous and eroneous data sometimes, so don't take it as read. | ||
| | #8 | ||
My System: Dreambox 7000, Skystar2 | The reason I was suprised is that we don't really do cable here, and there are probably very few folks here that know much about it. I'm surprised that S2emu does anything for you. Which exact card are you using, so I can have a look at the spec/functionality? How have you got ProgDVB set up? Which provider are you with? You have me interested now... :ch3 | ||
| | #9 | ||
| Apologies for the late reply, holidays and that... I figured this is probably not the best place to ask about cable, but there are few places that I know of except the shack and I can't get registered. Anyway, I don't think this problem is specific to cable or satellite its most probably my PC. The card is the Fujitsy Siemens D1121 DVD C pci card. All I can say about my set up for ProgDVB is that its standard, I simply installed it as per the app instructions. Maybe I don't understand the question you'll have to spell it out for me. I'd rather not be specific about my provider if you don't mind. Unless you really want to, I wouldn't waste anymore time on this than you already have. Fact is I can get the channels I want to work and I should be happy for that at least. Cheers | ||
| | #10 | ||
My System: Dreambox 7000, Skystar2 | Hey, no probs m8. Thanks for sharing what you have already. As you say, I don't think we're going to be able to help you other than with the obvious driver updates and maybe a re-install of ProgDVB (or how about trying MyTheatre V2.76?). Good luck. STICK | ||
| card, fujitsu or seimens |
Similar Threads | ||||
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| BBC (Sky) FTA Card What card does what ? | ShayK | Sky Digital (BSkyB) and Astra 28.2 East General | 5 | 26-01-2005 06:42 PM |
| hang on " sending TRAPCODE" and a new titanium card | hfathollahi | Cards & Programmers General | 22 | 18-12-2004 08:00 AM |
| Pentamedia card not initializing | s*t*a*r*m*a*n | Computer Discussion | 1 | 14-07-2003 05:07 AM |
