n00b questionsDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 27-12-2004
| Hi, Please bare with me, this is my first post and I am rather new to satellite hardware etc. My issue is as follows, my partner and I wish to build a HTPC, we have a pritty good idea about the hardware and software we will be using. However when it comes to integrating satellite TV I am getting rather confused! I have looked at several forums and DVB PC card products. I have conculuded it is totaly impossible to find a PC card solution which allows access to anything other than FTA channels. Idealy I would want one that can receive FTV and the Sky digital subscription channels I am subscribed too. But that is not possible? and no way round it? The next best thing as it where would be to find a solution for controling my SKY Digibox from the PC, is this in any way possible? Perhaps through the digibox's RS232 interface? Or worst case through a PC IR output device. My partner and I arn't scared of writing our own software for this, just need pointing to the right specs etc to make it work. Any help you could give us would be appreciated. Thanks. Anne. | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Hi Anne78 - I think you will find that is no real solution for decoding a Videoguard signal, except with a dedicated reciever and card (SKY) if that is what you want to do. As for control of the box - what do you want to do with it ? ![]() L | ||
| | #3 | |||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | AFAIK, there is no published API/SDK/interface standard for data interchange with the digibox, and I'm not even sure if the RS232 port can be used to reflash the firmware on the box (although this is it's most likely intended use, even if it's disabled). Further, there is no publically known way to decrypt the S*Y (UK) encrypted video signals other than within the digibox/card itself (and that includes the PC, Linux devices or any other 'experimental' hardware). The PC card solution is quite capable of decrypting other encrypted video streams, though not all, and with no reliability. This is real hobbyists stuff and isn't for the casual user. It's a lot of hard work to keep stuff 'open'. Also the PC sat card generates a lot of heat, and does not sit well in a small confined space like a silent HTPC-case environment. Big spaces and plenty of fans are the order of the day unless you want a seperate box via USB. Sorry, all bad news I'm afraid. ![]() LOL, P.S. having said all that, this 'rare' post has just appeared here which might provide a smart way of going about it, if it could be made to work... http://www.satellites.co.uk/php-bin/...65&postcount=2 | ||
| n00b, questions |
Similar Threads | ||||
| Skybox n00b questions | Cheekykid | Sky Digital (BSkyB) and Astra 28.2 East General | 1 | 15-07-2006 06:22 PM |
| HOTBIRD 4 satellite receiver questions | Balood | Digital systems | 6 | 05-04-2005 08:59 PM |
| questions on magic module | ez_livin | Magic Module | 13 | 10-06-2004 12:28 PM |
| Questions for the Cam experts | Samba65 | Cams and decoders General | 14 | 13-05-2004 03:00 PM |
| Magic CAM: what the future holds? | jimbo | Magic Module | 10 | 14-09-2003 08:22 PM |
