decoding a mpeg 4:2:2 feed with skystar 2
Old 16-04-2005   #1
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro
hi to all can anyone tell me if they are encoding a 4:2:2 feed with progdvb, i am getting the 4:2:0 feeds ok im using the skystar 2 ,thanks in advance to all
iwol is offline   Reply With Quote
Old 16-04-2005   #2
My System: FTE Max, Skystar2.3 and Skystar2.6, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Not sure but....
I seem to recall that a 'moonlight filter' will decode 4:2:2
Low Profile is offline   Reply With Quote
Old 16-04-2005   #3
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
You can download the filter from -
h**p://www.elecard.com/download/
Llew is online now   Reply With Quote
Old 17-04-2005   #4
thanks for replys but ive been to the elecard site and theres loads of downloads could you tell me which one it is and what do i do with it in progdvb thanks
Old 17-04-2005   #5
can anyone help please
Old 18-04-2005   #6
Simplest way to get the Moonlight decoder is to install/re-install ProgDVB- tick the option to "Register Elecard Filters" during the install process.
This will then install and register the Moonlight filter which should allow viewing of 4:2:2 feeds. You can tell if your system is using the trial version of the Moonlight filter, as it has the funny 9-way box thingy overlaid on the picture.
stan_drew is offline   Reply With Quote
decoding, feed, mpeg, skystar
Similar Threads
Antenna Feed switches: 12V & Diseqc jeallen01 DISH SETUP: Single sat, Multi-Sat & Motorised systems 3 16-02-2004 11:56 AM
Best video qualtity, Skystar 1 or 2? mtiller Satellite PC Card Receivers & Internet by Satellite 13 03-12-2003 09:30 PM
Skystar 2 not working properly ckrys1 Satellite PC Card Receivers & Internet by Satellite 11 31-10-2003 10:54 PM
David Blaine - Above The Below- feed needed Shahid Transponders & channels 1 07-09-2003 08:37 PM
