Multivision Scratch Problem solved.
Old 21-04-2005   #1
ali4u's Avatar
My System: hotbird
Smile Multivision Scratch Problem solved.
Progdvb uses more resources ... the processor usage goes to 100 % with multivision ..i dont know why this is so ...even i have 512 mb ram , 1.0 GHz Processor , and still the problem occure while watching multivision...i dont why this is so ..ney how i m working on it to get solved ..but for the time being i suggest you use alt-dvb as it decrease your processor upto 80 % and 70 % .. let me help you solve your problem .. get this link
www.geocities.com/smile_aali
download the zip file and extract to the root i.e ( c:\alt-dvb ) and create a shortcut on you desktop for the programe ... i have put everything in its proper location but better you get latest softcam fromwww.rdi-sat.com by match1 section.
and extract the alt-dvb folder ..and e.thing will b fine. thats it.
ali4u is offline   Reply With Quote
multivision, problem, scratch, solved
Similar Threads
Multivision Problem Solved! Digital2 Adult satellite channels 31 12-06-2005 10:47 PM
Have a problem MPEG2 DVD conversion mgharbawy Computer Discussion 4 21-06-2004 10:02 PM
Have a problem with Vision Plus mgharbawy Satellite PC Card Receivers & Internet by Satellite 1 15-02-2004 10:47 PM
is this a diseqc problem doggy DISH SETUP: Single sat, Multi-Sat & Motorised systems 14 05-09-2003 02:44 AM
Aston to Diseq poitioner problem BazelAd DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 20-08-2003 07:21 PM
