Skystar2 remote with winlirc
Old 21-04-2005   #1
My System: need info about ad_600
Question Skystar2 remote with winlirc
Has somebody find how to use the remote technisat with winlirc on the progdvb software...
I have try to learn signal from remote, use the original one, cofnigure progdvd in control windows, but nothing looks working...
Please could you help me to fix it..
Regards
sanpec is offline   Reply With Quote
Old 22-04-2005   #2
farr's Avatar
My System: Windows XP Professional, Skystar 2, TM5200D+ Super, 1m motorised dish [62E-58W]
I am actually using WinLIRC, my own old Sony HiFi remote control and a slight variation on the COM port receiver (details at http://cmail.info.kuzbass.net/%7Enav/WinLIRC.htm).
Open up WinLIRC, click Reconfigure and then the Raw Codes button. Point the remote at the IR sensor and press a few buttons. You should get some lines on screen starting with pulse and space with numbers after them. If not, the problem lies in either the configuration of WinLIRC or the IR circuit. Make sure you have selected the correct type of device, the correct COM port and the speed (mine is set to 115200 for reference). If that is all okay, then click Learn and make WinLIRC learn the remote. A Technisat remote file is provided with DVBViewer but I cannot vouch for its accuracy. Please post again if you need more help.
My grand total for all this btw was £1.28 - all for the IR chip; I re used an old 4-pin CD-ROM audio cable and the old Sony remote control was from a long since discarded hi-fi.
farr is offline   Reply With Quote
Old 22-04-2005   #3
Dumb Satellite Babe
Satslut's Avatar
My System: Technomate 5500CIP Force 1145S Pace 2600 SS2 pci & USB Channel master 1.8m 1.2m & HH motor AMD 64 bit, Linux & Windows XP2
Originally Posted by sanpec
Regards
I emailed the guys at progDVB, they told me they were working on it and would post it on their web site as soon as they had the fix
Satslut is offline   Reply With Quote
Old 23-04-2005   #4
tHKS ..
I will test it tonight....
I have a receiver on my pc (send with the skystar2 card).
If i use the technisat.rc provide with dvbviewer, it doesn't work in progdvb... so.. let and see...
Old 05-05-2005   #5
My System: Skystar2, 85cm dish
I also would like to get the remote working with DVB Viewer. I even brought a Skystar 2 remote from Ebay. Can anyone explain how they did it ?
Also the remote sensor is on the end of a small com port plug in adapter. How can this work properly if at all as with most pc's being used any com port is on the back of the pc and as we know an infa red signal needs to be line of sight, how daft can you get !!!
satvfan is offline   Reply With Quote
remote, skystar2, winlirc
Similar Threads
The Ultimate Idiot Guide! For Idiots by Idiots!Answers,Questions,Tips + Tricks: RTFM! T_G Dreambox Guides, Stickies and FAQs 51 11-07-2009 01:14 PM
About SkyStar2 With B2C2 Shipset ......Question? tabozada Satellite PC Card Receivers & Internet by Satellite 6 19-04-2006 10:03 PM
keys in dreambox pistolpetos Dreambox General 27 21-02-2006 02:32 AM
Bb Aio "Silver card" remote calculator T24 Editors, Utilities and miscellaneous downloads 0 14-10-2003 11:30 PM
Echostar remote control protocol? easysat Digital systems 0 10-10-2003 10:16 AM
