anyone watched hdtv with prog dvb and skystar2Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro |
hi to all has anyone managed to watch the hdtv channel on 13e with prog dvb, 11013h 27500,located the channel but its just black anyone with any help please p.s. using version 4.26 | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | Can't remember, but watched 1080 on 19.2E no problems. Needed to change the filter I was using in MT V2.76 though to eliminate the pixellation. Sorry, I know this doesn't answer any of your points, but it may give you some hope | ||
| | #6 | ||
| Regular Member Join Date: 16-03-2005 Location: malta
My System: skystar 1 + Motorised dish. | Me too I tried watching an HDTV channel which is fta on hotbird, and I get blocky picture and poor sound. I have a skystar 1 and also 2, and on both of them same thing happened, using both myTheatre and ProgDVB. | ||
| | #7 | ||
My System: Dreambox 7000, Skystar2 | OK, I've been doing a little bit of testing on the HD Forum test channel on 13E 11013 Horizontal 27500. My findings so far? With MyTheatre V2.76, you can change the graph settings until you find the one that works best. I used the default ones for ages with no problems, but HDTV was really blocky and kept locking up. Changed graph settings to Win2000 V-Cyberlink, A-InterVideo - and it's perfect. On the Skystar 2 the pictures are stunning. Give it a go if you have MT installed. I've also had this working on HD1 on 19.2E in the past. Same graph solution. Get it free here :- _http://www.sat.joy.ro/download.html Don't know if you can change 'graphs' in ProgDVB, and even if it was possible it would probably take me a week to find out how to do it as it's the most poorly laid out piece of 'kin software I've ever used. With the standard install of the latest version it's 90% OK, but a bit blocky/locky. Picture comes straight up though. It's obviously either on a data-bandwidth limit somewhere, is experiencing a processing bottleneck, or there is a software/driver glitch. HTH somebody. STICK | ||
| | #8 | ||
| Member Join Date: 20-05-2005
My System: SKYSTAR2 80 DISH 2 LNB 60 DISH 1 LNB | if u have the module "BROADCAST SERVER" ON IN PROGDVB the HD channel cant work try 2 set it off in the module list | ||
| | #9 | ||
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | hi to al im just getting a black screen and a bit of sound now and again with mt i can also only use the bottom 3 graphs but its the same wit them all any ides please also do i set the hardware icon to skystar1 ,sky to pc or twinham and compats im using a skystar 2 | ||
| | #11 | ||
| Member Join Date: 30-12-2004 Location: iran
| How active remote control skystar2 in progdvb? sancem2004@hotmail.com | ||
| | #14 | ||
| Member Join Date: 30-03-2005
My System: Skystar 2, (so far) Hopefully 80cm dish & 0.3db monoblock P4 2.53Ghz O/C 3.02Ghz Athlon XP 2200 HTPC Barco Data 701 CRT Projector 87" wide 16:9 screen | I managed to watch a few minutes of the HDFORUM channel last night, the picture on my Barco CRT projector was stunnining, had a blocky picture until i changed the filters to the Nvidia dvd decoders. played pretty smoothly on a AMD xp2200, but i couldn't get the filters to stick with progdvb. I will try and do some more testing, oh and the quality & level were about 35% Regards James | ||
| | #15 | ||
My System: Skystar 2, (so far) Hopefully 80cm dish & 0.3db monoblock P4 2.53Ghz O/C 3.02Ghz Athlon XP 2200 HTPC Barco Data 701 CRT Projector 87" wide 16:9 screen | Best, result ive had so far is using the cyberlink powerdvd v5.0 filters in progdvb, this gives stutter and pixel free pictures in high defininition., thats on a AMDxp2200 c/w 256 mb of ram, the default elecard filters just wont do. Hope this helps James | ||
| | #16 | ||
| Regular Member Join Date: 12-06-2005 Location: East Sussex
My System: Quad core 4GB Ram Vista 64bit 24" 245B Samsung widescreen TFT. Nvidia Zotac 8800GT AMP! Edition 512MB graphics card + Skystar 2 sat tv card with DVB Viewer Pro 3.9 Intel mac mini dual core with eyetv 3.0.1 running Cinergy S USB satellite box 1m Fu | Yes now 3 or 4 HD channels / feeds on AStra 19. The new Canel + channel is also excellent. Also on 5 west there is a copy of the HD Forum. I think havfing a HTPC helps with a good graphics card, certainly going up from 128MB to 256MB and doubling the ram to 1gig made a huge difference wirth me, very processor hungry these HD feeds! Also another prog Skyview seems to use a lot less processor power than ProgDVB for the HD channels | ||
| | #18 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | A google search for "Skyview DVB" brings up several links where you can download it. ![]() _http://www.dvbskystar.com/dvbindex.html | ||
| | #20 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | No, that PC isn't working at the moment I'm afraid. | ||
| dvb, hdtv, prog, skystar2, watched |
