MyTheatre 2.60.2....
Old 11-04-2003   #1
Big Hairy Bugger
Big Ted's Avatar
small changes......
Most of them is installer related:
-FIXED: installer: some issue was with installing intervideo decoder on non-english windows.
-UPDATED: installer: now you may choose from several predefined installations: Typical, Update, Full, Full(except codecs)
-UPDATED: installer: now you can choose between compressed/uncompressed channel storage.
-UPDATED: now commad line switch /play can be omited. MyTheatre <file_to_play> is enough to start playback.
-UPDATED: Changes in DVBCore source filter. Now DVBCore prefetches some small amount of data after switch channel then starts show. It will must eliminate some temporary sound cracle (i heard this when i used 5.1 channel output, where 2.0 channels worked fine). After optimizing whole DX code this prefetch doesn't take many time upon channel switch. So, try it.. i'll continue optimize DX code to achieve acceptable results. Thus this part of code is like beta-part.
Full Package with included everything you need:
http://www.hippo.ru/~sorgelig/MyThea....60.2.Full.exe ~8MB
- this pakage includes Codecs, Almos everu known working Plugins (MD & DVBCore), Remotes, Skins (which i found).
Lite package which doesn't include Codecs and RC Plugins:
http://www.hippo.ru/~sorgelig/MyThea....60.2.Lite.exe ~3.8MB
Tiny package which doesn't include Codecs and RC Plugins, SoftCAMs and Skins(except default one):
http://www.hippo.ru/~sorgelig/MyThea....60.2.Tiny.exe ~2.5MB
Update package since 2.60 version to 2.60.2 which include only updated since mentioned version files:
http://www.hippo.ru/~sorgelig/MyThea...0.2.Update.exe ~800KB
-this package will install update only if you have already installed one of Full, Lite or Tiny package.
Big Ted is offline   Reply With Quote
Old 11-04-2003   #2
rolfw's Avatar
Real name: Rolf
Thanks for that BT, just as a matter of interest, I presume that the transponder information is stored in the .TPZ file, is there an editor around for this?
Rolf
Old 11-04-2003   #3
Big Hairy Bugger
Big Ted's Avatar
Change name to .zip
Also you can delete it and change to old transpoders directory so that you can copy across old info to save a rescan.
ps also copy satellite contents as well.
Old 12-04-2003   #4
My threatre problems?
I am currently running My threatre 2.55.2 with skystar1.
I have downloaded the two later versions but when i use them certain fuctions crash my p.c. and just restart my p.c. does anybody have any clues thanks
stan01 is offline   Reply With Quote
Old 12-04-2003   #5
rolfw's Avatar
Real name: Rolf
Strangely enough Stan, this latest version has decided to restart my PC as well, but only seems to happen if I have the browser running at the same time.
Rolf
Old 19-04-2003   #6
E2R
Startup problem
ProgDVB works fine on my system but I find con*x channels break up. I read that My Theatre was great with con*c so I downloaded 2.60.2full and installed it.
All I get is a screen similar to Win media player that has two satellites installed, one being Hotbird. That's it! No poictures, not even clear channels. Do I need to swith it on?
How do I switch it on to recognise the SS2 card.
Any other suggestions, please?
E2R is offline   Reply With Quote
Old 19-04-2003   #7
rolfw's Avatar
Real name: Rolf
right click on the screen and go to DiseqC and LNB settings, you can select the satellite and LNb settings there.
Rolf
Old 19-04-2003   #8
E2R
Many thanks, problem fixed.
E2R
Old 29-04-2003   #9
the links don't seem to work??
Skid.UK is offline   Reply With Quote
Old 29-04-2003   #10
rolfw's Avatar
Real name: Rolf
Try also the Link in Nobbly's big links list, there is one listed under DVB Card downloads.
Rolf
mytheatre
Similar Threads
Idiot's guide to MyTheatre strawberry Satellite PC Card Receivers & Internet by Satellite 1 24-09-2004 06:51 PM
how can I watch seca2 channels with MyTheatre? makhmalak_79 Satellite PC Card Receivers & Internet by Satellite 2 17-09-2004 05:27 PM
problem of remote control with mytheatre mc_magic Satellite PC Card Receivers & Internet by Satellite 3 18-07-2004 07:22 PM
Offline MyTheatre geronimo Satellite PC Card Receivers & Internet by Satellite 0 02-07-2003 12:03 PM
MyTheatre Scanning Sat hangs? pedro Satellite PC Card Receivers & Internet by Satellite 5 14-06-2003 07:06 AM
