ss2 init error please help im stuckDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 06-02-2005
hi had ss2 card for a while now and trying to get hh 100 diseqc to work... ok ive downloaded diseqc 1.2 skystar 2 v1.8 ive backed up and replaced the skynet.sys file in windows system 32 drivers......loaded my theartre and clicked on plugs ins there is the diseqc i configured it with my long and latitude i dragged the satellite tp list in fine....rebooted pc a dozen times but i get the above error what ever button i click on in configuration my motor is the gb sat h100 motor but im lost as to why this error...read on the forum abt setting it up but no one seems to have had this error....its as if the the plugin is not talking to my skystar 2 pci card....im running the 428 drivers....... please any advise would be great.... paul..... | ||
| | #3 | |||
it will for some reason start twinham which is in list but not my ss2...i know i had this problem b4 but i cant remember what the cure was....but tnx for the reply i thought i had bad breath....never tried to get card to move dish b4 so im new to this side...tnx paul | |||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | You need to install some of the other guff that came on the installation CD. The setup4PC stuff or whatever it's called. Install everything except DVBViewer and then reapply the new DiSEqC skynet.sys, plugin (.exe and .dll and sat list etc). Once you've done that, you can stop the stupid setup thing starting at boot by removing the shortcut from the startup folder in 'All Users' on XP. STICK | ||
| | #6 | ||
| Long Term Contributor Join Date: 01-05-1999 Location: scotland
![]() | Yes good advice install everything. i have had that ss2 init error aswell and installing all the drivers and stuff usually works. i get the mpeg codec missing if i dont. I do not use disecq though i probably could but i just use a pace sat programmer and type in the number of the satellite i want and then just go to disecq in progdvb and choose the satellite im on then tune in the channels that way. | ||
| error, init, ss2, stuck |
Similar Threads | ||||
| please help me upgrade one EUROSTAR Eurobox-9700 | gsmsikar | Receiver software, international Section | 9 | 09-09-2006 04:27 PM |
| SS2 card Jumper setting ? | bobit | Satellite PC Card Receivers & Internet by Satellite | 5 | 14-08-2005 07:33 AM |
| progdvb & ss2 help | andy-gi | Satellite PC Card Receivers & Internet by Satellite | 5 | 05-07-2005 06:24 PM |
| New SS2 driver! | arraknid | Satellite PC Card Receivers & Internet by Satellite | 11 | 29-09-2003 09:42 PM |
| SS2 and DXR2 | refinechange | Satellite PC Card Receivers & Internet by Satellite | 0 | 23-06-2003 01:43 PM |
