Mono LNB
Old 26-05-2005   #1
Mono LNB
Thinking of purchasing this:
Ebay.co.uk/ws/EbayISAPI.dll?ViewItem&category=60838&item=5775532666&rd=1&ssPageName=WDVW" target="_blank">http://cgi.Ebay.co.uk/ws/EbayISAPI.d...sPageName=WDVW
i have a 80cm dish
first off, is that a Ku-Band LNB, i dont know what it means or if any significance, but thats what my current one is, i think, as it says it in progdvb/mytheatre.
Second thing-= How do i put it on ?
The dish is currently pointing 13e do i leave it there shove first arm of lnb on? and second one is to the left i think. or do i point it to 19 and do vice versa? or do i point to 16 and move the big metal arm and try and centralise them?
Should be fine with ss2 right? has diseq1.0 doesn't it?
TIA
Moy
moyhim is offline   Reply With Quote
Old 26-05-2005   #2
farr's Avatar
My System: Windows XP Professional, Skystar 2, TM5200D+ Super, 1m motorised dish [62E-58W]
i have a 80cm dish
TIA
Moy
It is a Universal Ku-Band Monobloc and so would be suitable. I believe you align the rightmost LNB for 13E after fitting it to the collar and the left one should then need only a little alignment for 19.2E, however I have never installed a dish or LNB in my life! Just posting here to say yes it is Ku-Band and yes certainly suitable for a SS2 as they can do DiSECQ switching - have a 4/1 switch operating my own 3 LNBs excellently myself
Make sure you also have a dish size of at 80cm or so - I believe it won't work reliably with a much bigger dish (>90cm).
farr is offline   Reply With Quote
lnb, mono
Similar Threads
Mono block LNB setup fab123 DISH SETUP: Single sat, Multi-Sat & Motorised systems 3 29-12-2001 04:30 AM
