DVB Viewer Full VersionDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 03-06-2005
My System: Dell XPS Gen 5 |
Good afternoon, Having bought a Skystar2 a week ago I have tried every which way but loose, (no pun intended) to enable SoftCSA. I have read the idiots guide to using DVBViewer and can honestly admit... i am an idiot Do any fellow memebers now of a clear precise thick persons guide to a) getting the respective software b) how to install it properley If anyone can help then thanks. | ||
| Farrukh Join Date: 14-03-2005 Location: Pakistan
My System: Star Track World-in-box II+CI | its sad to hear that but i think thats much better to use TV tunner card with sat receiver becoz it is not going to share your system memory as compare to DVB card | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Get ProgDvb (a viewer) and S2 emu (a softcam) and something called softcam.key (a set of keys) You will have to go to the links page here if you want them or google for them. Set up ProgDvb and put all the files that came with s2emu into the progdvb folder along with the key file. Thats it ! | ||
| | #5 | ||
My System: Dell XPS Gen 5 | Thx Lancelot. done everything you said. Total newbie here, i am currently point at 28e. I am assuming the info you provided is for use with another satellite. Please advise Thx Matt | ||
| | #6 | |||
| | #8 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | 13 east is probably your best soloution, given what's available at the moment. L. | ||
| | #10 | ||
| Regular Member Join Date: 12-06-2005 Location: East Sussex
My System: Quad core 4GB Ram Vista 64bit 24" 245B Samsung widescreen TFT. Nvidia Zotac 8800GT AMP! Edition 512MB graphics card + Skystar 2 sat tv card with DVB Viewer Pro 3.9 Intel mac mini dual core with eyetv 3.0.1 running Cinergy S USB satellite box 1m Fu | So this softcam will allow me to watch encrypted channels with a Skystar 2 card ? Which packages conax ?? | ||
| | #11 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | No C*nax isn't compromised at the moment. Sorry ![]() L. | ||
| | #12 | ||
My System: Quad core 4GB Ram Vista 64bit 24" 245B Samsung widescreen TFT. Nvidia Zotac 8800GT AMP! Edition 512MB graphics card + Skystar 2 sat tv card with DVB Viewer Pro 3.9 Intel mac mini dual core with eyetv 3.0.1 running Cinergy S USB satellite box 1m Fu | OK I've got this s2 emu prog and a softcam.key (recent ?) So far I am not able to decode anythng, what channels should I be getting on 13 east ? Where do I get the latest softcom.key ? | ||
| | #13 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | With the latest S2emu and recent keys then you should be opening lots up there including the TPS bouquet (M**tiV*sion chnls) amongst others. For new keys go to the links section of this forum and follow some of the links till you get one dated no more than a few days old and drop them into the ProgDvb folder. L. | ||
| | #15 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Excellent. Nice when it all comes together. L. | ||
| | #16 | |||
| | #17 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | 12731 H for the channel. I can't believe you can't find ANY softcam.key from the links page. Have another go. L. | ||
| | #18 | |||
| | #19 | ||
My System: Quad core 4GB Ram Vista 64bit 24" 245B Samsung widescreen TFT. Nvidia Zotac 8800GT AMP! Edition 512MB graphics card + Skystar 2 sat tv card with DVB Viewer Pro 3.9 Intel mac mini dual core with eyetv 3.0.1 running Cinergy S USB satellite box 1m Fu | Thanks but the link you gave (now gone) gives 2 keys none of which will decode universal, file dated 11/6 ?? | ||
| | #20 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Ok - the spoon thing I frown on generally, but it seems you are having problems. Electrojan you can jump in now , help this guy and return the favour as I see you are watching this thread. What did YOU do ?? L. | ||
| | #21 | ||
My System: Dell XPS Gen 5 | OK no worries 1st things 1st uninstall progDVB. Then goto the folder through windows explorer and delete anything that is left , then delete the ProgDVB folder from your C: drive. 2nd. Reinstall ProgDVB 3rd. make sure your satellite dish is pointing to Hotbird --- very important else this is a waste of time then click 'Settings' then 'DisEqc'. Clicl on little green light in window and push button 'Add LNB'. Use drop down box to locate 'Hotbird'. When found click ok / apply and once again click OK.4th. Click 'Channel list' then 'Channel search' and point the channel search to Hotbird (should be the only Satellite in the list). Scan transponder Hotbird for all available channels (takes about 5 - 10 mins) 5th. Close ProgDVB 6th. Place all s2emu files in ProgDVB folder 7th. Place softkey in ProgDVB folder 8th. Run ProgDVb 9th. Click Plugins on menu at top of screen. Ensure 'enabled' is ticked' and 'AutoECM' is ticked. 10th goto channels list and open up each folder. you will see green 'V' for open channels and red 'V' for encrypted channels. Click on each channel. (theres 1000s of channels in total and this will take a while. The software will decrypt the channel and bingo. This is how i did it. | ||
| | #22 | ||
My System: Quad core 4GB Ram Vista 64bit 24" 245B Samsung widescreen TFT. Nvidia Zotac 8800GT AMP! Edition 512MB graphics card + Skystar 2 sat tv card with DVB Viewer Pro 3.9 Intel mac mini dual core with eyetv 3.0.1 running Cinergy S USB satellite box 1m Fu | ecotrojan thnaks for going though all this but you did'nt need to really! I have been using Prog DVB for tha last year or so I am very familiar with setting up etc. I am decoding certain scranbled channels now on 19 east and Hotbird with S2emu. All I am wanting actually is the latest softcam.key file which has the keys for the Sky Italia ' S*ca channels as mine does not decode amounst others the Studio UNiversal channel another guy mentioned, on 12.731 I think Btw with 'found' channels in info I get missing : S*ca2.cfg ??? Also I have found another plugin like s2emu called NVcam, anyone tried this ? | ||
| | #23 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Which ver of S2emu have you got there ?? You should have all of these L. | ||
| | #24 | |||
| | #25 | ||
| Member Join Date: 07-10-2005 Location: California
My System: Fortec Star Dynamic Decoder 90cm Dish USALS Motor SkyStar2 PCI PROG DVB DVB VIEWER | Hey guys I am also having issues with DVB Viewer. I would love to download ProgDVB but I have a sky star USB card and Prog doesn’t support that. I also didn’t get the idiots guide to DVB viewer. Can some one give me some clear instructions on how to use soft cams and keys with DVB Viewer. Thanks James | ||
| dvb, version, viewer |
Similar Threads | ||||
| restore software version for strong 4350 | dreher | Receiver software, international Section | 2 | 25-03-2005 12:55 PM |
| Can i patch my sammy with version 118? | giorgik | Receiver software, international Section | 2 | 11-01-2005 09:07 AM |
| Freeview owners rule out full return path for service | net1 | Terrestrial Television, Digital and Analogue | 3 | 18-12-2004 07:09 PM |
| trying to understand the guides | s*t*a*r*m*a*n | Satellite PC Card Receivers & Internet by Satellite | 21 | 19-11-2004 10:32 PM |
| DVB Viewer and C*n@x | damhy | Satellite PC Card Receivers & Internet by Satellite | 3 | 01-11-2004 11:32 PM |
