newbieDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 12-06-2005
My System: ft1000mp tl922 ma5b | hi all my first post .. so be gentle...i was thinking about getting one of the skystar2 dvb pci cards.. there is a few on Ebay i was thinking about taking my old sky digi dish down and putting up a 70-80cm dish fixed at 13 e.. what would i be likley to get with this set up?..ie what can the sofcams currently decode??i used to have a motoriesd analouge system a while a go so i am a bit out of touch!!!!.. thanks a lot for reading | ||
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | gbsurf I am not up to date on softcams as I do not use them but the problem is that as soon as somebody posted something it would be out of date. You really need to have a good read of all the various forums. I would recommend you keep the digidish where it is and use a 2nd dish for your 13deg which you could later motorise easily enough for even more sats. | ||
thanks for reply toppervte33h ..its just an idea ..i dont have a sky sub anymore but if the softcams are not reliable then i wont bother...i will try to find out a bit more about the system first... ok cheers ..gbsurf.. | ||
| newbie |
Similar Threads | ||||
| newbie newbie | saxfoon | Digital systems | 1 | 18-01-2004 08:32 PM |
| sorry! yet another newbie | badgermo | Satellite PC Card Receivers & Internet by Satellite | 2 | 01-01-2004 06:33 PM |
| newbie diseq motor help | pluto | Satellite PC Card Receivers & Internet by Satellite | 2 | 28-08-2003 11:25 AM |
| Newbie needs help with Sky | Skullface | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 26-08-2003 06:21 PM |
| newbie newbie | pluto | Satellite PC Card Receivers & Internet by Satellite | 1 | 26-06-2003 01:49 PM |
