Recording video with Skystar2 and ProgDVBDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 31-08-2004
Hi there, I promise I searched for this before I tried but I never found anything relevant. I have for some time now been trying to record video using my SS2 and ProgDVB both of which work perfectly fine. However after I finish recording and open the file, no picture appears, sometimes even the sownd is kind of slow and I was wondering what the reasons for this could be? Any ideas? Which program would you recommend me for recording off of my SS2 and above all, which codecs do I have to have? I appreciate any help, Many thanks! | ||
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | The codecs installed with PowerDVD5 work great. You can then use that app. to view. I'll admit that this is the easy way out... ![]() elecard decoder/codecs also do it IIRC. | ||
| progdvb, recording, skystar2, video |
