ProgDVB Nexus Reset
Old 01-07-2005   #1
My System: Athlon 2400 Nexus-s Progdvb sg2100
ProgDVB Nexus Reset
ProgDVB,SG2100, Athlon 2400
About once a week I have to put put the SG2100 back to zero using the manual button and then re-set the motor using the re-set button. I used to program every thing from scratch, ProgDVB,DiseqcU,sat positions,ect, once a week but I soon found out all I had to do was put the motro back to zero and hit the re-set and every thing was ok for another week or so. I discovered that when the motor will not move on a channel change I can go into ProgDVB and use the positioner option and move the motor that way but in the end I still have to put the motor back to zero and hit reset. I have tried to fix this for the last 8 or 9 months, have read a lot of post's but never found an answer yet. If any one out there has a fix for this I would appricate some feed back.Here on the east coast of Canada in Nova Scotia is a good location, I am able to see sats all the way from Hispast 30.o W to Eco 121.0 W. I just joined this site today an this is my first post.Missey
Online Now
Missey is offline   Reply With Quote
Old 01-07-2005   #2
rolfw's Avatar
Real name: Rolf
Hi Missey, welcome to our forum.
I'm afraid I'm a little out of practice on the PC Cards, but will move this to that section, as that's where you are most likely to get some help.
Rolf
Old 03-07-2005   #3
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
Is it doing the same thing with different viewers (MyTheatre etc) have you tried to install a later ver of ProgDvb and tried that ?
If you are able to move the motor manually then it sounds like the commands are not reaching the motor correctly. Sorry to state the obvious but got to start somewhere .
L.
Lancelot is offline   Reply With Quote
Old 04-07-2005   #4
I some time use Ritz or MyTheatre to view t/v but I have never programed either one to move the motor. I thought no sense having to many software's on my computer to do the same job may cause a conflict. I have tried Prog 4.38 and 4.40 but right now I am using 4.26 and 4.48 to move the motor.When I switch to a different channel after a few days or so the Sg2100 will not rotate so what I have been doing is, disable the refresh channel if signal lost option and then , going out to the motor and rotating it back to zero using the manual button on the motor and then re-set it using the re-set button on the motor or, I can move it east or west about 20 deg or so using the positon option in progdvb diseqc set up. When I say I can't move it manualy I mean it will not move manualy using Diseqcu. options --Go To Angular Position or Go To Selected sat. After I use either one of the above methods It works fine for a few days then I do it all over again. Warm or cold weather dosen't seem to make any difference. I was going to take it a part and see what kind of lub they use at the factory but it seems like a weak battery in an old car, now and again it needs a little extra bost to get it going in the morning. I have twin cables about 65 ft long running through pvc conduit under ground out to the dish. last fall I changed both cables but it did not make a difference.Thanks for post, Missey.
Old 19-07-2005   #5
kalamar's Avatar
I had some problems with an SG-2100 last year that had loose coax jacks on the motor and it was very unstable I replaced it with a warranty item.. but dont have much faith in SG-2100 and DVB card,seems lot of problems not had with a regular receiver/motor setup.
kalamar is offline   Reply With Quote
Old 10-08-2005   #6
Try this kvaDiseqc0.6 plugin for progdvb
Creator25 is offline   Reply With Quote
Old 12-08-2005   #7
kalamar's Avatar
Also best to use latest ProgDVB to its 4.55 today.
nexus, progdvb, reset
Similar Threads
diseqc 1.2 and progdvb taynet Satellite PC Card Receivers & Internet by Satellite 5 08-03-2007 03:51 PM
progdvb & ss2 help andy-gi Satellite PC Card Receivers & Internet by Satellite 5 05-07-2005 06:24 PM
Progdvb Question? ripley607 Satellite PC Card Receivers & Internet by Satellite 1 02-03-2004 12:13 PM
Please help with progdvb and emu raemno Satellite PC Card Receivers & Internet by Satellite 1 19-01-2004 10:48 PM
ProgDVB and Multidec API darknebulae Satellite PC Card Receivers & Internet by Satellite 2 01-09-2003 11:01 AM
