Skystar2 + Smartmouse + Valid cardDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Regular Member Join Date: 28-06-2005 Location: Belfast
My System: Skystar2 PCI P4 2.6Ghz 1024MB PC3200 XFX 6800GT |
Is it possible to decrypt Irderto2 and/or Viaccess2 channels using a Skystar2 pci + smartmouse card reader + a valid subscription card with a software cam? Thanks, | ||
| The Following User Says Thank You to paradoxni For This Useful Post: | ej_ebrahim (15-04-2008) |
| | #2 | |||
| Member Join Date: 22-06-2005 Location: Tunisia
My System: Sat SkyStar2 PCI Ver.2.6D | yeah You cand do it but before that download this file and put it in plugin file for the program you use to watch TV if you use progDVB put it in this directory C:/ProgDVB after that open ProgDVB and go to plugins then u see IrdetoCAM click on it then Go to Setting and choose a Com Port u connect a Smartmouse. now put a Valid Card for Irdeto2 and Have Fun This will not decrypt any channels without a legitimate Card
| The Following User Says Thank You to mansoura For This Useful Post: | ej_ebrahim (15-04-2008) |
My System: Skystar2 PCI P4 2.6Ghz 1024MB PC3200 XFX 6800GT | i keep getting " incoming ecm instruction.....signature wrong" over and over! I have all the settings correct | ||
My System: Skystar2 PCI P4 2.6Ghz 1024MB PC3200 XFX 6800GT | im thinking perhaps the new card cannot be activated by this method, perhaps it needs a proper set top receiver. Anyone in Northern Ireland fancy activating me card? | ||
| | #5 | ||
| Member Join Date: 01-12-2004
| Try md irdeto cam 1.07_01 beta...... This version doesn't have autoECM, so you will have to manually select the ecm (go to the channel properties in progdvb and double click on the correct ecm...) You will also need to enable EMM for your card to activate, leave it running tuned in the channel for about 1 hour to activate and receive the keys... Good luck... | ||
| The Following User Says Thank You to deliol For This Useful Post: | ej_ebrahim (15-04-2008) |
| | #6 | |||
| | #7 | ||
| Regular Member Join Date: 22-08-2004
| can someone help me in this matter? Are there any specific settings need to be entered in the IrdetoCAM ? | ||
| The Following User Says Thank You to hamham For This Useful Post: | ej_ebrahim (15-04-2008) |
| | #8 | |||
Just double click on it and watch irdeto cam monitor.... should work However, if mdirdetocam plugin cannot activate your card, you will have to use o receiver box with an irdeto cam for it... then put the card back to your pc, will work fine | |||
| | #9 | |||
| | #10 | ||
| Have you enabled the EMM setting??? Also enable the Emm Logging , it will create a file in the progdvb folder with all the emm commands... send it to me and i'll sent it to the author of irdetocam plugin, maybe he can help.... ( a screenshot of the plugin monitor while recieving emm's would help too) | ||
| | #11 | ||
My System: Skystar2 PCI P4 2.6Ghz 1024MB PC3200 XFX 6800GT | ok just sent the card back to where I bought it to be activated and tested as working...still not working here thou | ||
| card, skystar2, smartmouse, valid |
Similar Threads | ||||
| Skystar2 + Smartmouse + Valid card | paradoxni | Satellite PC Card Receivers & Internet by Satellite | 2 | 08-03-2006 05:47 PM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| Pentamedia card not initializing | s*t*a*r*m*a*n | Computer Discussion | 1 | 14-07-2003 05:07 AM |
