ss2 problems think its a codecDiscussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Specialist Contributor Join Date: 18-07-2005 Location: uk
My System: Technomate 1500ci + 1000d super + skystar 2 pci card 1M Motorised dish Ivacon twin lnb pc + laptop on network |
hi when i watch some channels on ss2 card i find the video skips everynow and then and realy anoying is ther a codec im missing or does an one know what problem is i got everything else working ok | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Could be your PC as SS2s are hungry beasties. What spec is it ?? L. | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | That should be plenty fast enough. Which viewer are you using and which drivers ? L. | ||
| | #5 | ||
My System: Technomate 1500ci + 1000d super + skystar 2 pci card 1M Motorised dish Ivacon twin lnb pc + laptop on network | prog dvd TechnisatDrivers4.3.0 it dont do it on all channels but on a few like video-n - dmand and mtv and tps foot the pcture flickers for couple seconds every now and then never done it on my reciver box | ||
| | #6 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Tricky one that. You could try the 2.17g drivers from Technotrend.de. Used to get the same effect with the SS1 when it lived with an AMD K6 3 400 many moons ago. L. | ||
| | #7 | ||
My System: Technomate 1500ci + 1000d super + skystar 2 pci card 1M Motorised dish Ivacon twin lnb pc + laptop on network | no that never worked is ther a way to turn timshifter of as they maybe causing it | ||
| | #8 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Having an SS1, I can't 'try out for real' your problem but I didn't think the SS2 supported timeshift ?. | ||
| | #9 | ||
My System: Technomate 1500ci + 1000d super + skystar 2 pci card 1M Motorised dish Ivacon twin lnb pc + laptop on network | | ||
| | #10 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | So disabling does what ??L. | ||
| | #11 | |||
| | #12 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | Try setting the buffer and cache sizes to 0 L. | ||
| | #14 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | So still the same with min buffer size and all other programs (outlook. IE6, all other stuff ) closed down then. Not even a small difference ? L. | ||
| | #15 | ||
| Regular Member Join Date: 04-09-2004
| When we are using progdvb to watch fta channels there shoudn't be any problem. we may face problems when we want to view scrambled channels (with yankse etc). Use dvbviewer software supplied with ss2 or u may use dvbdream to find out the problem. Usually problem persist with software installations . uninstalling and reinsatlling the software and drivers may rectify ur problem. | ||
| codec, problems, ss2 |
Similar Threads | ||||
| progdvb & ss2 help | andy-gi | Satellite PC Card Receivers & Internet by Satellite | 5 | 05-07-2005 06:24 PM |
| Sky+ recording problems | pjb | Sky+ (Plus) and PVR Systems | 4 | 17-06-2004 11:46 AM |
| Few people seek help for sex problems | net1 | The Meeting Place | 0 | 22-08-2003 08:11 PM |
| Problems... Help ! | iwearflares | Analogue systems | 2 | 11-08-2003 08:01 AM |
| SS2 and DXR2 | refinechange | Satellite PC Card Receivers & Internet by Satellite | 0 | 23-06-2003 01:43 PM |
