ProgDVB Crash ..??Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 04-04-2005
My System: Dish w/2xLNB Beast of a PC with: X800Pro @ 590mHz AMD64 3400+@2.865gHz SkyStar 2 rev. 2.6C Barco Graphics 801S CRT w/120" 4:3 Screen | Just reinstalled XP and v4.3.0 drivers for my SS2 2.6c. I also installed ProgDVB 4.55 Full as I did last time (and it worked perfectly well then), but now I get this utterly annoying message saying "C++ Runtime Library blablah.. abnormal program termination" ...and it exits before it starts. Can anyone give me a hand here please? | ||
| | #2 | |||
| ASBO Club Member - Persona non grata Join Date: 25-10-2004
I see you re-installed OS so was working before so it must be a file missing or corupted. Please post exact messages you get,as this contains the answer to your problem. ![]() You maybe also look in OS (XP) log error file and see things | |||
| | #3 | |||
"Microsoft Visual C++ Runtime Library: Runtime Error! Program:...\ProgDVB.exe Abnormal program termination" ..and it's nothing to do about it when it first hits the screen. I don't think it's ProgDVB, maybe the SS2 drivers, but the most likely b****** is XP somehow.. are there any good codecs (for Mpeg2 etc.) known to work with this configuration I should try out? Has anyone else had this error and found what caused it to pop up? | |||
| OK I run Win2000 pro so I guess its different.I also use a Nexus-S card so I use hardware mode,is light load on computer. Sorry I cant help directly,there are a few on here that do run your setup so you should stay tuned. | ||
| crash, progdvb |
Similar Threads | ||||
| diseqc 1.2 and progdvb | taynet | Satellite PC Card Receivers & Internet by Satellite | 5 | 08-03-2007 03:51 PM |
| progdvb & ss2 help | andy-gi | Satellite PC Card Receivers & Internet by Satellite | 5 | 05-07-2005 06:24 PM |
| Progdvb Question? | ripley607 | Satellite PC Card Receivers & Internet by Satellite | 1 | 02-03-2004 12:13 PM |
| Please help with progdvb and emu | raemno | Satellite PC Card Receivers & Internet by Satellite | 1 | 19-01-2004 10:48 PM |
| Flying Underpants Cause Highway Crash | net1 | The Meeting Place | 0 | 22-07-2003 08:25 PM |
