Pinnacle PCTV SAT (need software):confused:Discussion on systems using a DVB satellite receiver card SD or DH in a pc. | |
| Member Join Date: 18-05-2003
| Hi I have a pctv sat dvb pci card. I tried to use winstb+mdyanksse. But still no image on any pay tv channels. I know, even I succed im my project its not a real time tv and I need to record it and latter view it.Anybody know another software that can handle .dll plugin's for Pinnacle pctv sat? Best regards Kian | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Have you added the latest softcam key Kian? You should be able to watch tv in real time as well. | ||
| Hi & thank you dear Rolf I dont know if the softcam.key is valid or not but the last update of file was 16.05.2003. other specification of my are: OS : win XP files in winstb folder -------------------------------------- winstb.exe ver 0.066 full install settings.ini SoftCam.Key SS1WinSTB.dll TABCTL32.OCX ttdvbacc.dll DVBCore.dll StreamReader.dll WinSTB.GRF dvbs.grf usrc.ax ************************** files in MDPlugin ----------------------------------------- Yankse.dll (1.0.4.2) yankse.prv yankse.ini yankse-sid.cache yankse-ecm.log yankse-pmt.log SoftCam.key.used ***************************** Also I attached an image of yankse monitor of ABSAT/POLSAT that you can see it. I dont know, maybe I need another .dll or need to change anithing in setting. It seem allthings are ok, but still no image or record(recorded .ts file size seem normal too!!!) again thank you for your further helps. Regards kian | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Sorry Kian, had to remove the softcam key and also the graphics, they show keys and the posting of keys is forbidden. If you wish Nagravision channels to clear, you will need the current keys, they change keys pretty much daily. | ||
| | #5 | ||
| Hi Rolf. Sorry, I didnt meant to show keys, only wanted to show results of yankse.dll . anyway, I still have my question. is there any thing forgotten in my winstb/mdplugins folder? where is my fault? only keys? Regards Kian | ||
| | #6 | ||
| Member Join Date: 18-08-2004
| Try getting rid of yankse-ecm.log & yankse-pmt.log get new version of softcam key using google as search engine, also download prog dvb then put softcam key & yanksee plugins into prog dvb directory. oh don't forget to put auto ecm=1 in yanksee config | ||
| pctv, pinnacle, sat, softwareconfused |
Similar Threads | ||||
| multiswitches | spiney | Tutorials & How To guides | 10 | 24-02-2007 05:43 PM |
| have you problems with pinnacle pctv sat 400e & progdvb | ewalida | Satellite PC Card Receivers & Internet by Satellite | 2 | 16-06-2006 04:36 PM |
| Request for help/advise about PCTV Sat problem | mitro_al | Satellite PC Card Receivers & Internet by Satellite | 2 | 05-09-2004 05:38 PM |
| Pinnacle PCTV SAT CI card | pkiraas | Satellite PC Card Receivers & Internet by Satellite | 3 | 13-07-2004 04:17 PM |
| !!Help!! Need a sat signal finder. (Loaned or Hired) in UK | jAk | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 1 | 25-01-2004 06:59 PM |
