MyTheatre ...stuck?
Old 24-05-2003   #1
loiterer
Pullet_Surprise's Avatar
Question MyTheatre ...stuck?
Got the technisat card working with the lastest drivers (XP Pro). Mytheatre will display any chosen channel info at the bottom, so its getting a signal. Using directx v9.0, all drivers upto date sound, video etc. Installed full version of MT v2.65.5 with all req'd codecs etc, I'm using latest softcam. Still cant get picture "Error code xxxxx" and "Cannot initialise directshow playback
I have tried all the xp playback hardware options with no luck. Worked once, before I installed new mobo, ram etc. Cant think what to do next?
Q: I get error "Cannot Initialize DirectShow". Why?
A: Many causes may produces this error.
Make sure recuired codecs are installed and right registered.
Don't understand this bit, shouldn't the codecs install automatically?????
"Speak softly and carry a big stick; you will go far."
Pullet_Surprise is offline   Reply With Quote
Old 24-05-2003   #2
rolfw's Avatar
Real name: Rolf
What may be worthwhile is to disable the PC card in the devices list, then restart and enable it, may also be worthwhile uninstalling and re-installing the latest MyTheatre. There certainly seems to be a certain amount of Mobo's that the crad doesn't get on with as well.
Rolf
Old 24-05-2003   #3
loiterer
Rolf,
This device is listed twice as:
1. 1394 net adapter.
2. B2C2 broadband receiver pci adapter.
I've disabled 1, tried MT, no luck. Uninstalled them both, rebooted and it only asks for item 2 drivers. XP seems to just add the card as a 1394 net adapter by default?
Old 24-05-2003   #4
Maybe this helps
If you have SS2 you can try this.
http://www.hippo.ru/~sorgelig/DVBCore.v2.68.03.zip
1) copy included SkyNET.sys to win\system32\drivers
2) reboot(!!)
3) copy DVBCore.dll to MyTheatre dir.
mrdollar is offline   Reply With Quote
Old 25-05-2003   #5
baztheman's Avatar
I found i had that problem after i ran the core update so i could pump the voltage to my H - H motor from my 5kystar2 card but found it worked out ok when i kept the core the same and the skynet.sys was updated.
the dvbcore.dll was causing the video problem,hope this helps...baz
baztheman is offline   Reply With Quote
Old 29-05-2003   #6
loiterer
thanks fellas,
No joy yet, think I might have to revert to old mobo for now?
Old 29-05-2003   #7
rolfw's Avatar
Real name: Rolf
Have you tried it with ProgDVB Pete?
Rolf
Old 30-05-2003   #8
loiterer
No, but the technisat TV4Pc works. I'd try EZdvb again if I could get hold of it, all the links seem dead?
Old 30-05-2003   #9
rolfw's Avatar
Real name: Rolf
You may find it on this forum http://forums.dvbnetwork.com/index.p...9ec945f79d3b32
But I would certainly give ProgCVB a go, particularly as conax is no longer an issue.
Rolf
Old 11-06-2003   #10
loiterer
Huzzah it works.
Just an update for what its worth. The soundcard and sat card were conflicting, not that any clues were given by XP in devices? I had to rearrange the cards one at a time in various pci slots before things worked. This coupled with installing/uninstalling software and drivers was a real headache. The only clue to what was wrong was when lineout sound on the souncard suddenly stopped working after three weeks of it being fine.
Computers who'd ave' em'?
mytheatre, stuck
Similar Threads
Idiot's guide to MyTheatre strawberry Satellite PC Card Receivers & Internet by Satellite 1 24-09-2004 06:51 PM
problem of remote control with mytheatre mc_magic Satellite PC Card Receivers & Internet by Satellite 3 18-07-2004 07:22 PM
Offline MyTheatre geronimo Satellite PC Card Receivers & Internet by Satellite 0 02-07-2003 12:03 PM
MyTheatre Scanning Sat hangs? pedro Satellite PC Card Receivers & Internet by Satellite 5 14-06-2003 07:06 AM
DiSEqC motor stuck ! bibi bear DISH SETUP: Single sat, Multi-Sat & Motorised systems 9 10-02-2002 11:16 PM
